Installed my new HU, Amp, and Subs!
gmcjohn
So I got my Kenwood DDX514 and all the other stuff back in January, but until recently I haven't had time to install anything. I had the day off on Friday and routed the wires for my amp, and yesterday I put my head unit in. Now until yesterday I had never soldered anything and wasn't sure exactly how the process would go (the instructions were some what vague). Using what I've read on here and a couple demostrative youtube videos I did everything myself, which is big for me because im only 17. Everything worked great when i plugged it in and I am very satisfied.
There was one problem, however, with the antenna hookup. The antenna wire from the yukon doesn't fit into the antenna hookup on the head unit. Im not sure if I need an adapter or not. I don't remember reading anything on here about that, so if anyone knows what to do please let me know!
Thanks in advance!!
I will pt pics of the install once its all done!
vatahoelt
NoVa
good to see that you got everything hooked up.
but yes, you'll need an antenna adapter. i need one too, but since i don't listen to regular radio, i've been putting it off. i believe you can pick one up at autozone or advance.
gmcjohn
gmcjohn
Thanks a lot. I'm kinda embarassed to admit this on here with all the perfectionists but for right now i have a piece of tin foil wrapped around the stock needle to make it work until tomorrow, you know just so i can show it off! lol what adapter am i looking for? is it anything special or is it just a standard antenna adapter?
TnTahoe
TN
u can pick the adapter up at your local walmart for about $8
gmcjohn
gmcjohn
okay i got the antenna adapter and it worked great, BUT when i put everything back in place the headunit wouldn't turn on! I have checked allmy wires and nothing is loose. So now I'm really not sure what to do! any suggestions?
TnTahoe
TN
check the fuse on the radio, make sure you are getting power to the hu, use a dmm and check the constant hot and ignition, make sure u have a good ground, and make sure your hu harness is pushed all the way in
gmcjohn
gmcjohn
i checked the fuse already and i checked the ower to the head unit by plugging the stock hu into the factory harness. Nothing happened. I'm not sure where to go from here
grnrpr68
Davenport IA
check the fuse in the truck for the radio also then unplug the head unit and plug it back in just to make sure its getting power
gmcjohn
gmcjohn
which fuse is to the radio? I was looking yesterday and I wasn't sure which fuse it could be. I'm thinking it has to be the fuse or the interface because my amp isn't turning on either so i know its not the head unit.
---------- Post added at 11:13 AM ---------- Previous post was at 11:01 AM ----------
Nevermind i found it, and infact it was blown.
gmcjohn
gmcjohn
Update: Everything hooked up and buttoned up! Took a few pictures:
TnTahoe
TN
is the blue box for the steering wheel controls? if so how many wires did you have to connect to it?
oh wait I just noticed that you dont have any steering wheel controls
gmcjohn
gmcjohn
It is actually for the Bose system and steering wheel controls. I don't have steering wheel controls as you noticed, but if I did the same adapter would have worked. It's the PAC-GM bose. It runs about $65-$75 depending where you get it. All in I soldered 36 wires together so that means 18 pairs. You can do all the soldering outside the vehicle if you're smart. If you forget about the Amp power wire like i did, then you have to do that in the car. I got the head unit for $365 with a 5 year warranty- it was a steal!
jackal78
