installed ccm 2.5
pm80
07 yukon 305/50/20 terra grapplers and corsa sport
Looks awesome! With your experience with your tires...if I go with the Trail Grapplers (295/55/r20) do you think they will be an okay size? I do have a Z71 so the fenders are a little bigger and the tires have more tread on them...just wanted to see what you thought..thanks!
P
pm80
My rims have a +16 offset and barely rub on one side. I don't think they rub at all on the other side. I think with that tire you should be fine. Also it only rubs on the inner plastic and not on the lower valence or the side steps. Your tires would be a tadd narrower and with the stock wheels you would be pushed in a tadd since it has an +35 offset so I couldn't see it being a problem. The roughly 1/2 inch taller tire doesn't seem like it would be an issue at all it is all going to be the width. I also saw were most people on the the chevy forum removed there lower valence anyway.
2 E L O
Omaha, NE
Looks great! Looks like you installed the rear 1" spacer, as well?
Any other plans for it?
emann_01
looks great!!!
what rims are those? do you know if they sell them in black?
P
pm80
The wheels are MB motoring Yuma's. I did install the rear spacers and it was really easy. I put jack on both sides and took one wheel off at a time. It dosen't say to in the instructions, but you have to unbolt the sway bay to get it to drop low enough.
scottd
