Hello all,
I'm looking at a 2008 Yukon Denali with 131K miles. According to the carfax the following repairs have been performed:
Miles/Date Issue
44,926 Left door lock replaced @ GMC Dealership
69,839 Inside door handle replaced @ GMC Dealership
79,980 Inside door handle replaced @ GMC Dealership
94,411 Brake pads replaced, rotors re-surfaced, engine mounts replaced, rear brake pads replaced, rear window defogger repaired @ GMC Dealership
97,861 Spark plugs replaced @ Local Shop 1
5/27/16 Recall #2049151 Passenger Airbag Inflators performed
104,309 Front brake pads replaced, front brake rotors replaced, spark plug wires replaced, spark plugs replaced, sway bar links replaced @ Local shop 2
7/07/16 Automatic transmission replaced, door handle replaced, door lock actuators replaced, inside door handle replaced @ Local Shop 2
110,452 Cylinder head gaskets replaced, cylinder head replaced, Exhaust manifold gasket replaced, intake/exhaust valves replaced, spark plug wires replaced, spark plugs replaced, valve lifters replaced @ Local shop 2
11/11/16 Rear brake pads replaced @ Local shop 2
127,015 Door handle replaced, inside door handle replaced @ Local shop 2
07/03/17 Alternator replaced @ Local Shop
08/01/17 Battery cables replaced
It appears that the routine maintenance schedule was followed as well. Is the above list a good sign that the vehicle has been well maintained or is it s sign of more repairs to come? What else should I expect to replace in the near future. The vehicle is a 2WD WITH Autoride. Any advide you can share will be greatly appreciated.
Thanks,
Trev
Miles/Date Issue
Thanks,
Trev
