Idle Speed Error
garrinchilders
Branson, MO
Hi Guys My name is Garrin, Long time troll, first time poster.
I am having a High Idle (1300-1500), cold start idle is around 1900.
When I stop at a stop light for any amount of time longer than about 30 seconds, I get a Service Engine Soon Light. and The truck will not have a lot of power when it comes time to take off. When I do take off and reach about 20mph the light goes out. I manages to create the situation in my driveway and grab the code while the light was on. It said "Idle Speed Error" (Code 35 i think, or 30something). I figure its either a faulty or filthy IAC solenoid. But before I go spend the 35.00 on an IAC solenoid I thought I would ask if you guys thought that would cause these issues.....
:emotions122:
1995 Chevy Tahoe
5.7 TBI 350
4x4 Auto
haks310
Got LEDs?
SoCal
Could be a lot of things. Easiest ones: check for vaccum leaks, especially at the base of the throttle bod; check the PCV valve, make sure it does not need to be replaced and is on there good; check the coolant temp sensor, wiggle the wiring around and see if the idle changes. If all those check out then move onto the IAC, EGR and TPS, all these affect the idle.
bass1775
Maryland
I agree, I recently had an idle issue when sitting still and it threw code P1115 (ECT) intermittent high voltage. I would have never guessed that. Replaced it, all is well.
G
garrinchilders
Branson, MO
I have replaced:
IACS
EGR Valve
Throttle Position Sensor
Plugs
Wires
Cap
Rotor
Fuel Filter
Still has the 1200 RPM idle and a CEL after sitting at a traffic light for 30 seconds, saying Idle Speed Error.
I have NO vacuum leaks
I installed the IACS correctly (per instructions)
I installed the TPS correctly also.
Hell everything is installed correctly (FOR SURE)
What is causing this?
I have dumped 600.00 in parts for this truck that I have had 10 days and only put 367 miles on..... I am really getting frustrated.:emotions122:
jdawg901
memphis tn.
my cel comes on when im on the eway but it will go off when i turn the truck off then back on wont come on til i get back on the eway after about a couple of miles at about 60 to 65 .can i check the code when comes on without turning the truck off or does it have to be off if so it doesnt have the cel light on ive replaced all types off sensors except for the egr valve and tps no vac leaks either.
G
garrinchilders
Branson, MO
LEAKING Throttle Body Gasket was the culprit of the high idle.... however it still stumbles and runs extremely rough under moderate to light throttle, when I let off the pedal it nearly dies.... what else?
haks310
Got LEDs?
SoCal
LMAO one of the first things I listed.
Have you checked your fuel pressure?
G
garrinchilders
Branson, MO
I am loosing fuel prime to the engine over night so I know the metering block in the basket needs to be replaced, and I have a brand new fuel pump laying there ready to go in, I have to drop the tank to remove the metering block and replace it with the replacement hose, and put the pump in, so I will replace the sending unit as well, because my gauge doesn't work and it isn't the cluster. I have reason to believe that the culprit of the running bad is the ignition module on the distributor, I am going to replace that with a known good one to test that theory, I have no personal means to check the fuel pressure so that will have to be done at a later date. I will post my findings.
AtomicHoe094
Atomichoe094
cleveland, OH
where you getting your ignition module from? Haks bought one called Dyna-Mod Ignition Module, he said he noticed some top end power on the freeway, its like 60 bucks, you should give it a shot..
johnsonwillie199
