I want to go lower
lx4life
hey jimmyp I will buy the extenders off you, let me know when u want to sell them.
NORCAL SS
SUV SUSPENSION GURU
since you bypassed autoride yes that kit will get you where you want.
J
Jimmyp19
NH
Update...
Sorry, your order failed!
You can attempt to purchase your basket contents again below:
Try Again
Any reason I got this message?
Thanks again
jimmy
J
Jimmyp19
NH
order went thru ready to roll
Right no brother perfect......
now with having the drop spindles and adding the drop struts, am I going to need anything else to assist in the alignment?
NORCAL SS
SUV SUSPENSION GURU
you might need camber bushings. I would put the rear spring in first with no spacers and adjsut the links then lower the front accordingly. usually with the 2/3-4 drop you dont need camber bushings in front.
J
Jimmyp19
NH
right, but seeing as I already have the 2 inch drop spindles in the front, and I am going to be adding 1 to 2 more inches of drop in the front...it could work out to a 4 inch front drop right?
NORCAL SS
SUV SUSPENSION GURU
your front is sitting high. I would put the rear kit in first and adjust it in. Lets say you put the rear springs in and its like 1 inch lower then you would put the front struts on wiht only a 16mm spacer and see where it sits.
Mlstammerjr
