I need a little help mac sensor question
fredbear
I have a 95 yukon 350 with a maf or mass problem I don't know is there a difference……. acts the same as the iroc when you shut off and turn it back on it resets……
heres my question I went o look it up to see how much the part is and i can't find it anywhere… but i can find it for the 96 yukon..
do you think there was some kind of swap in the engine area?
F
fredbear
sorry what i mean is I can't find a maf or mass sensor for a 95 yukon all there is out there are sensors for 96 yukons and up…….
I know if a maf problem cause it resets when I turn it off and on…power loss and stutter
the truck is a 95 and I do have a maf that needs replacing so why can't I find one to order
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Perhaps because you don't have one installed. Maybe you are referring to the MAP sensor. Located on a bracket on the right rear of intake manifold.
F
fredbear
I found out that the 95 don't have maf sensor but a map sensor its not like a maf at all where it passes thru a screen but its just a little plug
F
fredbear
finally changed it thanks for the help BUT it seems not to be the problem…..After i changed it the engine light still comes on every now and then,,
When its off it runs perfect very snappy throttle response….when the light is on it hesitates and sputters I even heard a back fire from the engine compartment……(maybe not though cause I have side pipes)
anyway I have also heard fuel pump could this be the problem will a fuel pump make a engine light come on?
F
fredbear
taking it to the garage on monday……no tools or time
F
fredbear
Sooo weird running great all day yesterday without fail as well as today cept once
Xay2Smoove
