I finally did my own break job
bamafutbal
gainesville fl ROLL TIDE ROLL
took around 3 hours to change front and back pads (centrix ceramic) and 2 front centrix rotors on my 07 ltz tahoe.
still have a few questions, is this cracked cover ok (second pic), rears did not have it
http://img408.imageshack.us/img408/4934/p1050443l.jpg[/IMG]
By bamafutbal, shot with DMC-TZ5 at 2010-03-27
and old pad off the front
IMG]http://img214.imageshack.us/img214/2396/p1050427b.jpg[/IMG]
at first glance, not much difference, but the inside thickness is much greater on the centrix
broken up cover
new pads are a little thicker
do not like all this corrosion and breakdown, will have to change rear rotors soon
took some effort to get the little rubber lip to settle down
new rear pads
another pic of the rust
pic of a new pad on outside and old pad on inside before it was changed
glad its finished, i will say that i am going to order new rotors next week and will have a local brake shop put them own. kind of like swallowing the tekillya worm, once is enough!
llllljrlllll
los angeles
what year is your hoe, I plan on changing my brakes soon. I've done it to my civic, but never to my tahoe 07, Did you need any special tool to push in the piston?
1dopeHoe
No, just a c-clamp and the old pads.
BC Lightning
Just did my brakes on my Hoe too!!!
Like said above, nothing special, just a c-clamp
I took my calipers off and painted them with caliper paint too
llllljrlllll
los angeles
Thanks 1dopeHoe and BC Lightning for answering the question. I'll try to see if i can do a tutorial on how to do it.
InTruckDesign
SW CT,
That cracked "cover" is the back of your stock pad. Due to corrosion it must have seperated from the pad and same corrosion held it to the 2 pistons...take it off and then install new pads.
B
bamafutbal
is there any value to the rotors, are they scrap metal or do i just throw them in the can. my 07 tahoe brakes so smoothly now, even in the rain today, braking was great. yes the c clamp, a hammer, and a couple of various size wrenches, is all that is needed and of course advise from the site and watching a youtube video on changing brakes
brice715
