I could really use some help - New shocks/springs/level.
zwanzon
Hey guys. I just installed new strut assemblies with Bilstein 5100's, Moog Springs and RC 2" level kit. I also did the lower ball joint. Upon getting it all together, there is a huge gap between the hub and upper control arm. The whole hub seems to be way too low. The top of the stut is lined up correctly. The 5100 shocks are set to the 2nd notch. Any ideas?!
kbuskill
NE. FL.
Put a jack under the lower control arm at the bottom of the strut or closer to the spindle and start jacking the truck up slowly.
You need the weight of the truck to compress the spring some so you can get the upper ball joint into the spindle.
zwanzon
zwanzon
Hey Ken. So I did exactly this and it was still too much of a gap. The LCA pretty much bottomed out trying to reach it to the hub. I ended up removing the RC 2" spacer and was just able to connect it all up. Maybe I wait a week or so to let everything settle in then try the spacer again?
kbuskill
NE. FL.
Are the Moog springs factory replacements or are they a lift spring or ???
zwanzon
zwanzon
Ok, I think you nailed it Ken. I ordered the Moog 81244 springs, which now looking closer, says it "Fits models with electronic ride suspension." FML.
So I have the wrong springs on there. Are these going to screw up the bilstein shocks? I read countless threads of people with this combo, not realizing they had electronic suspensions...
zwanzon
zwanzon
Here's what I don't understand. It looks like I was supposed to get the Moog 81246. But if you look at the spring specs, the "correct" spring is actually taller, which means it would have been even harder to get the hub all hooked up to the UCA...?
PG01
Up here to the right
Set the bilstien to the lowest level, with no rc spacer you should be level and then some. With Current setup (with spacer) springs and bilstien at 2 your cv angles may be too much and you will have problems and as you see youll never get it together. If you really want the spacer you should buy new ucas to correct your cv angles. Member on here knows best, he is
@01Konvict
kbuskill
NE. FL.
I think @Galante is correct... I read through too quickly the first time and didn't catch where you said you had the Bilsteins set for 2" of lift.
As far as the springs go you will be fine.
zwanzon
zwanzon
@01Konvict
If I have to take apart the strut assemblies and compress the springs again anyway, I might as well put in the correct springs. With the correct springs in there, can I still do the RC 2" spacer? Which notch on the bilsteins would I go with also? I'd still like to have a small lift/level as I got 1" spacer for the rears. My original goal was to raise the front 2.5" and the rear 1".
PG01
Keep springs, get ccm type strut spacer for above strut and get new ucas for angle. Keep 1” block for rear
zwanzon
zwanzon
Keep springs, get ccm strut spacer for above strut and get new ucas for angle. Keep 1” block for rear
Ugh, that's going to put me out another $500 just to have a couple inch lift. Is the car safe to drive on the way it is? I'll have to wait another week if I'm ordering all new parts. Which UCAs do you recommend? Thanks for your help btw.
PG01
Is everything back together and buttoned up tight? Do you hear any noises? As in cv grinding etc. your alignment is probably off now and i would say if you’re all tightened up and it wont hurt for a few days but bad alignment equals bad tire wear, pulling, putting extra wear on parts etc. Depending on how your truck rode before... it may be an entirely diff animal now. Did you check all ball joints, tierods and whole front end out? Kind of hard for me (or anyone for that matter) to say ‘yeah, go drive it, you’re fine’ over the internet.
zwanzon
zwanzon
I completely understand. I am more of asking in regards to the spring/shock situation. Everything is tightened up to all the correct torque settings and the other parts looked to be in fine condition. As I mentioned earlier, I did the lower ball joints as well and I know they are solid. I was going to finish up the rear today (shocks and springs) and I'm not too worried about the tires as they are in need of replacing anyway. I'm just trying to find the best solution according to my current situation.
01Konvict
Boats n Hoes
Raleigh/SML
You added a 2” lower spacer and set struts to second notch. That equals about 3”-3.25” of lift. I know your 2wd so that lift height should be ok but your upper arms will be resting on droop stops. Reset springs to lowest perch on struts. Run the spacer for 2” lift. Put stock springs off old struts on 5100s. Return new springs. Then get new upper arms and a 1” coil spacer for the rear. Then set front back up 2 notches for 3” lift if wanted to level with rear 1”. You will need to lift up on the the lower arm with a pry bar to attach to upper ball joint.
zwanzon
zwanzon
Hey @01Konvict . I'm actually 4WD. I had to take the CV axel nut off, etc. to replace the lower ball joint. The reason I got springs in the first place is that my Tahoe has 168k miles on it and I just figured I might as well do them since I was doing the shocks and taking the whole strut apart anyway. Are you saying new springs aren't really needed at all (meaning I don't need to do the rear spring either)? Also, your saying I'm not able to run OEM springs/2nd notch/2" RC lower spacer without replacing the UCAs? Sorry for all the questions, just trying to get educated.
01Konvict
Boats n Hoes
Raleigh/SML
Oh gotcha. Must have overlooked it in the one picture. Basically anything over 2” front lift starts the max of non lift. 2.5” puts the upper arms almost on the droop stop of the frame. So with your 2” lower spacer then struts set at second notch your around 3” range. If you can safely run that much lift with the cv angles then your uppers will be on the droop stops. So you need lift upper arms to clear stops and correct ball joint angles. Hope that clears things up for ya
zwanzon
zwanzon
So I just got off the phone with Moog directly, and the tech verified I do have the correct springs for anyone that may run into this same issue. The Moog 81244 are the "heavy duty" version and work perfectly on 4x4 applications. This was very great to hear that I don't have to take everything apart again.
@01Konvict - Thanks again for all your help. I have two questions:
  1. Do you have a recommendation on UCA's that work for the setup you mentioned above?
  2. How do you calculate if you are CV axles are at a safe angle?
01Konvict
Boats n Hoes
Raleigh/SML
Glad to hear the springs are good and you don’t have to tear them apart again. For the money I prefer the boxed zone ones. No real way to calculate safe angle. It’s more a visual. I’ve only seen one truck be able to run 3” safely. Everyone else is 2.5”. Just need to see pictures of the angles to determine if your good or bad. Another option to stay at that height is some cheap eBay diff drop spacers which lower the diff about 1/2” so you can push it at 3”.
Tiki
I ran Cognito UCAs and was very happy with them. More than a 2" lift is asking for trouble on these vehicles, sounds like you are on the right path.
scottd
