How to fix Hot Air when A/C is on. Install new air mix/blend door actuator
Tahoewhat
Ballin' on a Budget
TX
Well figured mine out, my a/c stopped blowing. No force, so i tried the blower motor, wasnt that as i found out, changed out auto climate, wasnt that, so then changed the blower resistor, connected to the blower and now i have full force a/c.. In my mind, it works better than before.. So i say change your blower resistor if any problems.
Cheddar
I have an 02 with the same issue, Whiteout, what year is your Tahoe? and where did you order the part from ? Nice write up !!!
bfranklin74
hello, thanks for the post. I have an 05 tahoe with the same problem as first stated. It blows cold on drivers side and about 300 degrees on passenger. I went and bought a brand new actuator today and followed the directions to a t now i still have the same problem. What do i do now??
Clemsonbloz
the blend door act for the other side is behind the radio! That was the easy one to get to.. There is also one on the drivers side above the hump that controls the air location(defrost,floor,vent, ect)..
Word of advice.. The back bolt in the long panel that he removed to get to the blend door act,,the aggervating one over the hump,,, throw it away.. the other fasteners will hold everything just fine, and you'll never deal with that aggervating bastard-bolt again!
bfranklin74
LMAO. bastard is one of the very few words i called that bolt. lol thats funny. Anyway today I figured out the problem. It was the actuator under the dash pad to the right of the radio. Now your taking some curse words. That was a JOB!!! took me about 2 hours but now im blowing COOOLLLLDDDD.. I think I did pretty good I only had 2 screws left over!! Not BAD! But I would suggest letting a mechanic do it!
gringoloco
Thanks for this. Took me forever to finger out what was going on with mine. One of those things you don't think about 'til you're sitting at a stoplight and your dash starts chucking fireballs...
WHITEOUT
WHITEOUT
Dont Hate-Appreciate
Phoenix
Hey everyone, so sorry about not replying, kinda forgot about this thread, since when I wrote it, no one seemed to care at the time!!! LOL. I know alot of people had this same problem, so... I'm back to help if I can.
I went to the junk yard personally, cause I wasn't about to pay the $75-$150 they want for these actuators brand new!! But that's me, and I picked up an extra one incase. Paid $20 total for 2. I have an 01' Tahoe, so everyone who is looking to do this needs to check the numbers on the back, or bottom of there actuator to ensure they are getting the right part. Seemed like different years, makes, models, had different actuators. So, make sure you get the right one.
Bfranklin74- yours sounds like the actuator behind the dash, cause your atleast blowing cold from one side, but not the other. And pretty sure that actuator behind radio controls left and right/driver/passenger, air. But didn't need to mess with that personally
As far as rear air goes. Mine was blowing cold in rear, but hot in front if I moved control knob. Rear always worked for me, so never had to mess with it.
Sorry again guys about not responding to my own thread!!!:emotions122:
Here to try and help now if I can.
Owe, and make sure to follow those re-learn steps!!! Actuator needs to be recalibrated to your system and how it is set.
twbauer
Just went through the blend door actuator mess and how it was fixed. I wrote up how I cleaned my actuator and got it working again. Thread is in the general section of the forum. Title is "blend door actuator or climate control".
florida boy
Valdosta, GA
Anyone know which actuator would cause hot air on the drivers side only? This has been happening about every 3 days now and want to get it fixed. Thanks.
WHITEOUT
WHITEOUT
Phoenix
I believe it's the actuator that is behind the radio, or possibly right under drivers dash. think that's the one that controls the air from left and right in front. someone else might know exactly, but I believe it's that one. Best way to figure it out, is get in there, move the door manually to see if it fixes the problem.
wrx600rr
could this be my problem only opposite? I have my heat on and only cold air comes out, the rear has heat but not the front so I know its not my heater core and its not leaking water anywhere in the cabin!
Clemsonbloz
the blend door actuator behind the radio does the passenger side.. driver side is above the hump...
I had the drivers side hot last summer,, took the actuator out, and apart and cleaned.. works like a champ..
the passenger side now is being dumb, and it's the bastard part behind the radio...
endo
Thanks for the write-up, just fixed mine on a GMC Sierra.
LaOrange
River Ridge La
Hi all
I have the same problem on all three Front Driver, Front Passenger, and Rear
at times They will work for months at a time Then drive you NUTS
If i turn the Truck off and restart it usually works again
I guess I will have to change ALL 3
Thanks
ScottyBoy
Shreveport, La
Mine has been acting up for damn near 3 years now. But I learned how to deal with it. The actuator will only get stuck if I turn it all the way to hot. As long as I don't turn it 100% to the right for complete hot then it will go right back to cold. If it ever gets permanantly stuck then I will definitely replace the actuator. LOL!
man i gottta 97 thats kinda doing the opposite. I have very little heat when cranked up to hot. No rear controls on my hoe but my thermostat, waterpump, radiatior is all new. Both hoses to heater core are hot to the touch so thats fine too. SOMEONE PLEASE help me here. cold as hell here in chicago and my mf heats acting up.
viperbluelx
Is that one considered the "main" actuator, or the "auxiliary" actuator? Mine is bad also but the parts store lists two, one's around $40 and the other is around $140.
dubyatf
My '04 Tahoe with climate control needed a blend door actuator. Symptoms were: Intermittent hot air with A/C on - usually it would stay hot. At first, as others have experienced, turning off ignition and restarting vehicle would correct. Even that trick eventually just stopped working however. When the hot aired flowed the blower would speed up too - when in the automatic mode.
GM part number was 89018365. I paid about $150 for it - I'm sure you can get it cheaper in Dorman or at thru an AC/Delco Distributor.
wwiizz
