How do I turn off LOW OIL alert??
Young Guy
I have an ‘07 Tahoe, and I replaced the original oil pan with one that doesn’t have an oil sensor.
How do I turn of the “Low Oil” alert??
I do not personally have the answer but I would "guess" that the harness for said sensor needs to be either terminated or needs a resistor of xx value, you might have to look up and see what the normal ohm reading is that computer see's and use a appropriate resistor
so for instance if 1ohm indicates low oil and 5 ohms indicates oil full then use a 5ohm resistor.
personally I would just add a sensor, it's going to be a fukton cheaper than a new engine
mikez71
What @SpareParts said... Looks like you ground that brown wire...
Young Guy
Young Guy
Thank you, I’ll research this further…
ScottS-Michigan
