horn problem ???????
pmdogg
montreal , CANADA
fuse ok
relay ok
but the horn not work
i want to know if you unplug the left horn the right still work or not
yukon xl 2001
pmdogg
pmdogg
montreal , CANADA
anyone know that ?
i realy need to know whats the problem because my alarm make no sound now
anybody can break into my truck
pleas help me thx
Rivieraracing
Have you tried checking for voltage at the horns when someone honks the horn? Also, haven't looked at how mine are setup up but I know that most horns have a power wire and are grounded from the mounting bolt to complete the connection, sometimes rust can get in between the ground location and not allow it to complete the connection, just an idea!!
pmdogg
pmdogg
montreal , CANADA
no i never check if the ground and 12v on the horn ...
I just bought the truck and the previous owner told me that his mechanic had to disconect the horn because he lost the remote of the alarm, me I installed a 2way alarm, I don't know what those missing to run the horn I saw a disconnected plug on the driver side to the horn is my hide I'm not sure if those for the fog or the left horn ?
Rivieraracing
So, hook up a voltmeter to the wire, the red lead to the wire and the black lead to a good ground on the truck, then have someone honk the horn or turn on the fog lights and see which one gives voltage!
pmdogg
pmdogg
montreal , CANADA
i will try to make this tomorow ,is not easy here with the cold and snow lol
i let u know tomorow about that thx
pmdogg
pmdogg
montreal , CANADA
ok i just checked the plug i have the wire one i think is black and the other is purple
12v in the black and 10v in the purple wtf 2 positive wire in da same plug?
and is all the time voltage no difference when i push the horn or the fog turned on
Rivieraracing
Post a pic up of what and where you are talking about, also try to get a pic of the horn setup as well!! I bet we can figure this out!
kickitandholdit
GA
if you un plug the right one the left still will work souds wierd but will work
drhdvm
