horn problem ???????
pmdogg
montreal , CANADA
fuse ok
relay ok
but the horn not work
i want to know if you unplug the left horn the right still work or not
yukon xl 2001
pmdogg
pmdogg
montreal , CANADA
anyone know that ?
i realy need to know whats the problem because my alarm make no sound now
anybody can break into my truck
pleas help me thx
Rivieraracing
Have you tried checking for voltage at the horns when someone honks the horn? Also, haven't looked at how mine are setup up but I know that most horns have a power wire and are grounded from the mounting bolt to complete the connection, sometimes rust can get in between the ground location and not allow it to complete the connection, just an idea!!
pmdogg
pmdogg
montreal , CANADA
no i never check if the ground and 12v on the horn ...
I just bought the truck and the previous owner told me that his mechanic had to disconect the horn because he lost the remote of the alarm, me I installed a 2way alarm, I don't know what those missing to run the horn I saw a disconnected plug on the driver side to the horn is my hide I'm not sure if those for the fog or the left horn ?
Rivieraracing
So, hook up a voltmeter to the wire, the red lead to the wire and the black lead to a good ground on the truck, then have someone honk the horn or turn on the fog lights and see which one gives voltage!
pmdogg
pmdogg
montreal , CANADA
i will try to make this tomorow ,is not easy here with the cold and snow lol
i let u know tomorow about that thx
pmdogg
pmdogg
montreal , CANADA
ok i just checked the plug i have the wire one i think is black and the other is purple
12v in the black and 10v in the purple wtf 2 positive wire in da same plug?
and is all the time voltage no difference when i push the horn or the fog turned on
Rivieraracing
Post a pic up of what and where you are talking about, also try to get a pic of the horn setup as well!! I bet we can figure this out!
kickitandholdit
GA
if you un plug the right one the left still will work souds wierd but will work
Modded
That Guy
Could just be the horn switch behind the steering wheel that went bad!
Rivieraracing
That's what I was thinking at first but then he said that he had voltage at both wires no matter if he pushed the horn or not and since the horn doesn't work at all right now, I'm thinking it's somewhere around the horns that's the problem!!
Post a pic for sure pmdogg, I'll take a look at my setup this weekend and see if I can help you out more!
pmdogg
pmdogg
montreal , CANADA
i made a red line to follow the wire
Rivieraracing
That plug looks like a fog light plug from what I can tell, you said that both sides of it have voltage? I'll take a look at my setup tomorrow for ya and see what I come up with!
pmdogg
pmdogg
montreal , CANADA
thx 4 the help i realy apreciate that
if i cant fix the problem i just got no choice to go to see the ex-owner garage
they suposed to fix 4 free but is 1hrs of road just for that
Rivieraracing
Well, for what I looks like, I think that plug is for fog lights but you shouldn't have voltage in both wires! I would take it back to the guy and have them fix it, who knows what they did!
pmdogg
pmdogg
montreal , CANADA
finaly i finding the problem this 2 horn is busted lol need to put 2 new anybody know the louder horn i cant install (like oem not train horn)
dizhai
