Hid help!
1sikyukon
SFV, CA
So I have had HIDs in my headlights for about 4 months and they have worked PERFECT!! The last couple of weeks I have had a problem with the left headlight. When i turn my lights on sometimes it will turn on other times it wont. When it doesnt turn on I have to keep turning my light switch on and off and on and off until it turns on. This is ANNOYING! and also can cause me a ticket out here if my headlights dont work. Any ideas....wiring? Ballast? It cant be the bulb itself because when i finally get it on the bulb works great.
Any info will be helpful....Thank you!
1sikyukon
SFV, CA
IDK? My friends got it for me as a gift. I mean they were working fine for about 4 months. I have a warranty on them So I wil deff call the company but im just curious as to why this is happening now? If it needed a relay it would of not worked since day one.
DenaliAK
Colder than you
Alaska
Probably a current draw issue, in which case a wiring harness might help, or a bad ballast. Take advantage of the warranty, though. It's what they are for.
Modded
That Guy
Don't know where you got that info from but most HIDs go bad for not having a relay!! Sometimes its caused buy a fault in the ballast because the starting power needed to power it can not be drawn from the stock wiring system. Other times it caused by the electrical system in the car going haywire because its having to provide the large starting power needed to power and HID system and not regular halogen bulb.
My HIDs started to flicker on the passenger side and all I did was add a realy kit and clean off the connectors and BAM, problem gone.
Lastly aftermarket HID problems are caused by Auto-Headlight system.
Do yourself a favor and get a relay and turn off your Auto Headlight/Approach vehicle lighting.:Handshake:
Zed 71
Pacific NW
Post the brand, type of ballast (e.g. digital start), and wattage. Perhaps post a pic of the package if you have one. Also what have you done to troubleshoot. Switch bulbs then ballasts left to right, tried stock lighting, etc.
I have the DDM Tuning HIDst on three vehicles and have not had any problems for ~4 years. If you have 35W rated ballasts, then theoretically the relay or harness is not needed because the startup power is less than stock (digital start ballasts). As said before, it is important to dissable the approach lighting function for the remote lock/unlock funtion through DIC. This will eliminate the short headlight run time which greatly shortens the life of HIDs.
Modded
That Guy
If you have 35W rated ballasts, then theoretically the relay or harness is not needed because the startup power is less than stock (digital start ballasts).........
Mine was 35W slim ballast and I had issues before the relay......
yukon07Artic
Dirty South ATL
Im newb and i didnt understand this phrase but it sounds important to me. Zed can you rephrase the statement so a 2 year old can understand?
I understood this as, "turn off your automatic headlamp system"
what is a approach lighting function?
tx07tahoe
Houston,Tx
If you install a relay then you dont have to turn off the approach lighting(lights that turn on when you unlock your truck at night). I had the same problem you did then got a relay and havent had problems since. I have slim ballasts for my fogs and hi's and it comes with a relay.
The black rectangle is the relay.
yukon07Artic
Dirty South ATL
im going to assume that the slims are safer and a smarter move for both low/highs and fog lights.
Fog lights especially because it produces more heat which will mean i will run into housing burn problems less.
its about the same price as the normal apexcone cause the Slims already come with a relay so i wont have to purchase a seperate relay right?
I'll have to cancel my first order and get SLims for my HID solution.
Any thoughts?
tx07tahoe
Houston,Tx
Ya you dont need a relay if you get slims with one in it. If you think its a down side slims cause the HID bulb to shine brighter.
yukon07Artic
Dirty South ATL
Thanks for the input, i made my mind up getting the slims.
Im goign to get the low/highs 5000k 55w. Would the 5000k 35W be similar in the color spectrum? . It said on ddm that 55w has a washed out effect. but when i checked the color spectrum for 55w and 35w they both looked super white, which is what im going for
Zed 71
Pacific NW
The slims are digital ballasts and those are the way to go (soft start).
TX07, I never hear the slim ballasts cause the HID bulbs to shine brighter. Where did you hear that?
Yukon are you sure the slim ballasts come with the relays. If so, that is new to DDM (combo that is). For 5000k 55W will be brighter than 35W and color wash will not be an issue. The color wash applies to high K ratings such has 6000k+ (for 6000k the normal output is blue but with higher wattage it will be more white [like 5000k]).
As far as the approach lighting, in the DIC scroll to the Remote Unlock Doors menu and in there you can select the option to turn off the Approach Lighting. The approach lighting means when you unlock/lock the doors remotely, the headlights will either blink (not good for HIDs) or stay on briefly during the night. I can't remember the exact lighting sequence, but this function should be turned off.
tx07tahoe
Houston,Tx
I had regular ballasts before and then went to slims and they are brighter.Plus the guy that put them in my Hi's said they where.
yukon07Artic
Dirty South ATL
I called ddm. I ordered my slims on sunday so i wanted to check up on them so i called them. I asked the guy if i need to purchase a seperate relay for it and he said no. he said it comes included with the whole system. but the guy was in sucha hurry to hang up on me that i really dont trust him that much. Dont expect top quality service from some of these people cause its holiday season and i they are trying to get in orders as fast as they can. They also told me that the lights wont be shipped until mid this week and ill most likely receive my hids somewhere end of next week. Ill call again to verify if it includes the relay
It might have been your perception of upgrading the lights, but the slims and the regular are both made with same technology. its not necessarily brighter but the can differ on calvin because the slims have a wider spectrum of white. either way it can be translated at bright, cause closer to 4300k the brighter the Hids.
---------- Post added at 05:58 PM ---------- Previous post was at 05:32 PM ----------
update!! just found out it does not come with the wire harness! i knew i couldnt trust the first guy. However the 55w already comes with the wire harness, but not for the 35w. A guy name paul helped me second time and he was much more courteous and friendly.ill let you know how this goes.
UPDATE!! 2!!!
LOL the 55w slims comes with the wire harness and 35 doesnt. 35w is in back order right now
Im getting 5000k for both 55w hi/low beam and 35w fogs 5202/h16
here is a pic of the spectrum
---------- Post added at 06:00 PM ---------- Previous post was at 05:58 PM ----------
[/COLOR]
DenaliAK
Colder than you
Alaska
I have always had to buy my harnesses seperately, so I'll be surprised if you actually get one included with your 55w kit.
I have never heard of slim ballasts being brighter then any other ballast. Theoretically that doesn't even make sense if everything else is equal (output power, kelvin, etc.).
tx07tahoe
Houston,Tx
Like I said before thats what the guy who installed them warned me about. But my cousin is getting slims for his fogs so I'll take pics before and after to see.
koomie98
