Anyone here can easily identify the alignment screws for the Denali's with HID lamps ?? Recently noted that the right side is aimed higher by a good 3-4 inches. Any help is greatly appreciated. (Is it under the plastic covers ?? Are you required to remove bumper cover ?? )
Also, can you simply do a bulb update to the foglamps thru the wheelwell liner ?? Any recommendations that match the HID's ?? Any bulb makers to avoid ?? (Used to use PIAA or CATZ -- Likely showing my age)
