Help with my drop trying to get the rear lower?
NathanJax
Vacation Nathan
Jax, Fl
do you have shock relocators in the rear? That could help. If not, go with a 1" smaller spring...
NathanJax
Vacation Nathan
Jax, Fl
Yeah but it's still sits kinda high
Sent from my SPH-L710 using Tapatalk
Then you'll have to do smaller springs. If those are a 4", you'll need a 5" and maybe grab some 1/2" spacers so you can adjust it to be level side to side and with the front.
NathanJax
Vacation Nathan
Jax, Fl
Question can I cut a coil off? Not sure
could you? yes, would I? No.
It could effect the spring rate which in turn would affect ride quality. IF you do, cut from the top, not the bottom.
I'd spend the $200ish and get new springs
T
torwanwilliams.tw
Ok that's good to know I'll get some springs I'm doing it myself so I know I'll make sum mistakes.
T
torwanwilliams.tw
Crown suspension 4"drop coils are you the man everyone talks about and if so what do I need to do next? I know I need to cut the bump stops bracket off. But like I said I'm not a experience and do you sell parts?
NORCAL SS
SUV SUSPENSION GURU
Good luck with crown.
1) do you have shock extenders?
2) what rear shocks are you running?
3),non autoride truck right?
Tell me that and I can dial in a price and kit for you
T
torwanwilliams.tw
Yes I do have shock extenders,factory shocks,no autoride
NORCAL SS
SUV SUSPENSION GURU
You will need to
1 do free travel mod
2 tgen I have the djm links and new bumpstops for axle for 110 shipped
3 I would move to belltech sp shocks 130 shipped
So 240 shipped for it all and cutting bracket off frame see how ride is. If still bad I would get rid of crown springs like I've done on many local suvs
T
torwanwilliams.tw
Thanks I wish you was in DFW area in Tx how do I order from you?
NORCAL SS
SUV SUSPENSION GURU
i do everything thru paypal. I woudl set you up a custom bill to your email
T
torwanwilliams.tw
Ok cool the measurement from the hub driver side 18 1/2 passenger side 18 1/2 the back driver side from the hub 19 1/2 passenger side 19 1/2
NORCAL SS
SUV SUSPENSION GURU
if it doesnt sit low enough after you do what i said you will need to go with my custom springs.
what size tires are on the truck? i would need ground to fenderlip measurements.
on a 305 35 24 on my custom spring and rear combo it sits at 32.75 from ground to fenderlip.
NORCAL SS
SUV SUSPENSION GURU
32 11/16 on my custom spring in rear.
What does your truck measure from ground to fenderlip all the way around now?
NORCAL SS
SUV SUSPENSION GURU
if you need 1.5 more you will need new springs for sure. Try first to cut off bracket and do what I said and go from that point forward
dizhai
