Help Please- Suspension RPO Code
tjmclea
I’ve been searching all over trying to figure out what type of air suspension is in my wife’s 2015 Yukon SLE. It has the trailering package with air shocks for sure in the rear. The rear shocks finally gave way so I am trying to get replacements ordered but I don’t see the standard Z55/Z95/ZW7 RPO code on the service parts identification. Initially I thought since it was a base model SLE it likely just had the premium smooth ride suspension but I’m not seeing that RPO code.
Can anybody identify what this thing has for a rear suspension based on the attached photo?
wjburken
Eastern Iowa
Well, if I am not mistaken, Z82 is HD Trailering; Z85 is HD Suspension.
Maybe @915_Tahoe can help get you part numbers since the last 6 digits of your VIN are visible in the photo.
are you 100% sure those are air shocks in the rear? do they have a air bladder?
please upload a photo of them.
T
tjmclea
Yep 100% sure. It has auto level and you can hear the compressor run. The shocks have the air bladder. I’ll snap a photo of the shocks when we get back home from the holiday weekend.
My biggest struggle is understanding what version of air shock I need to purchase to replace the stock shock. Thinking it must use the same shock as the other (non magnaride) air shocks.
well what's weird is the air shocks are z95 and that code is not in your list that was posted, nothing matches your z-codes
regardless you should be able to just order z95 oem or the comparable arnott and they "should" work just fine.
rockauto has them with a lifetime warranty and prices are fair.
Z95 is Magneride.
Z85 is your suspension package. For 2017 it's called Premium Smooth Ride with Air Leveler.
NHT is your max trailering package.
Your rig was made to tow the maximums.
T
tjmclea
Thanks everyone. I ordered 2 ACDELCO 5401721 shocks and a new Dorman compressor. Fingers crossed the shocks are correct.
Laurents10
