generalpuller
Read the article on how to do this but this is what happened... When I got my 15mm socket and ratchet to try and loosen the bolts I couldn't get them to budge... So I got the impact wrench... Well bolt number one came out however the bolt was rounded a little bit... When I attempted the second and third bolts I ended up rounding both ot them... I went and got some bolt out sockets from sears however the base of the socket will not go through the bolt access holes on the front of the hub so in other words they wont reach the bolts.... Has anyone had this happen to them before when the changed their hub assembly?? Any suggestions what I could do ??? Thanks
---------- Post added at 09:51 PM ---------- Previous post was at 09:36 PM ----------
One more question... When I do get the hub bolts out and put the new hub on, will I be able to go and get these 15mm bolts at autozone or other simular parts store the heads of the bolts are going to be trashed and I'm concerned about the bolt quality of the new bolts, I don't want a wheel to fall off on me.....
