Help! Lowered tahoe riding on bump stops
SaMoT
Hello everyone
I just installed the following on my 2002 4x4 Tahoe,
Front lowering torsion keys from Belltech
Rear lowering springs from McGaughys
I also installed Belltech lowering shocks
After I finished installing everything it looks amazing.
But after taking it for a ride, I noticed the front end was bouncing extremely. So I went back to look under and found that the front bump stops are compressed all the way down. Is this what is causing my tahoe to bounce so much? I turned the keys all the way up but that didnt work. Any Ideas on what I could do?
Those are actually " jounce stops" and they're designed to be in contact. They're not a solid rubber like the rear bump stops but a softer material. Yours look like they're worn out. Replace them; mine looked way better than yours but when I pulled them out to put new ones in, I could see they were deteriorated. New ones made a big difference. Dorman part # 905-208 . They're used like a leverage point for the torsion bars.
S
SaMoT
Looked it up and it seems it's a common thing. I ordered some z71 style ones that hopefully help either the problem. Will check back when I install them.
TheAutumnWind
Those jounce stops are toast. Did you trim the rears or do the free travel mod? Your going to want to.
I ended up trimming my new fronts- the new ones lifted my front back up 1/2" and I didn't want to run around out of level. I'm not sure about the Z71's- why did you order those? It would be good if they're shorter than your originals but I think they might be taller.
S
SaMoT
From what I was reading the z71s are more firm than the originals, and it should help with the bouncy ride I'm getting. I thought I would give them a try first.
And for the rear I left them stock, the back ride of the tahoe is fine. The problem is in the front and hopefully with the new jounce stops it will work.
Looks like you have the front dropped pretty low for just using lowering keys. That might be part of your problem. I haven't ridden in a rig with those installed but it was recommended to me to go with drop spindles for anything over an inch or so. I ended up with the Belltech ones and although it was more expensive, the front actually rides better than stock now. Hopefully the jounce stops will work for you, otherwise you know what needs to be done! There's always dropped lower control arms from DJM or drop spindles.
Aaron_L
Arlington, TX
That's way too low on keys only. Your control arms are sitting on the bumpstop cup. New bumpstops won't help in that case. You'll have to crank them back up and go with a lowered control arm or a dropped spindle if you want to go lower. Keys aren't good for a lot of drop. If they are cranked all the way up and still hitting you may have to reclock them.
NORCAL SS
SUV SUSPENSION GURU
lets start wtih the front
1) the key ride bad at more than 1 inch drop so you will need to turn the keys back up in front
2) if you want a 10x better ride and stay low i have the djm 3 inch lower a arms/belltech front sp shocks for 445 shipped and will include new bushings/blower balljoints.
3) theres a reason keys are so cheap loll
S
SaMoT
The bolt is almost turned all the way. I'll try installing the new stops when I get them, if that doesn't help I will probably end up going with either drop spindles or the new lower control arms. Thanks guys!!
I also plan on new sway bars, Panhard bar, rear upper and lower arms in the near future.
But first gotta fix the front that way I can install my wheels.
Aaron_L
Arlington, TX
In your pic you posted the bolts are backed out. When you turn them in it will raise the vehicle.
S
SaMoT
Will turn them all the way tomorrow in the morning and will check back. The keys were advertised as 3 inch.
S
SaMoT
I got the bolt on the key turned all the way now, this is how she sits. I took her out for a short test drive and the ride is way better than what it was not like stock but way better.
The jounce stops are still compressed in the arms just waiting on those to come in to install the new ones.
Thanks guy!!
Kcrowe79
