Help finding wheels with a better offset
Big Mama
Virginia
They’ll say that sometimes in case they think they’ll rub. What size tire are you going to run?
B
Found these wheels that I love the look of and the website only had them in 22x10 and with a offset of -19 and they say that they’ll fit. Does that sound right?
B
I’m pretty sure those ones I just posted will stick out way more than I need them to but I just found these that are 22x10 with a +10 offset which if I understand correctly should make my wheels go out about an inch and a half? That sounds about what I need to me. Would they fit?
CMoore711
Here are my old Raceline Surge 156B PVD Black Chrome 22" x 9.5" + 15mm Offset w/ 285/45/22 Michelin Defender LTX's mounted.
You should be able to find some 22" x 9.5" wheels with +10, +12, +15 offset options.
B
The fuel contra is my favorite looking wheel but they only come in 22x10 -19. That would make it stick out 2.14 inches more than it does right now. Do you guys think that would be too much?
Big Mama
Virginia
As mentioned mine s are 22x10 negative 35 offset with 305/45 tires. I’m lowered so I had to pull the front liner in a little but no rub out back at all. I’d think with 285’s you would be fine but to be sure call Tire Rack and tell them what you want.
B
Great, sounds good. Could you post a pic if you can of the car from some angles showing how the wheels stick out? I want to get an idea of how it’s going to look.
agmanw8n
