what if you can't get the part and what am i going to do?? go under the car every time I need to shift it??Another WTF Brent thread lmao. Or lame-o according to my buddy Jimmy. Which might actually be appropriate in this case.![]()
for future reference the part is (this is what customer support said) For the 2LM70 Transmission.
Nah just scrap out the car, it’s done in that case, right? It’s not like there might be another solution. Come on man you’re killin me!what if you can't get the part and what am i going to do?? go under the car every time I need to shift it??
i'll try to install it later too hot right now i got itNah just scrap out the car, it’s done in that case, right? It’s not like there might be another solution. Come on man you’re killin me!
2 hours? Must be a mafia-run shop.installed in 2min shop wanted to charge me 160$$ for 2 hours of laborView attachment 281616
they wanted to charge diagnostics feewhat kind of shop? I could see a place charging a minimum fee for putting it on a lift, etc but 2 hours is pretty excessive
but I already did that for free well they could have earned a new customer, I was planing on having the Aux transmission pump, new fluid and a double filter change to transmission(has two filters) ... i just had diagnostics done a month ago it came up inconclusive... but the aux pump is the "typical" suspect esp in the 2008/09 model..but I already did that for free
, you didn't tell them you had already "rigged it" to work and that's how you got there?
ya it doesn't need any grease, clean it real good and be sure you have it installed properly, I have one on mine it's never came offhaving an issue it still slipping off , It slipped off luckily it was in 'park' at the time... should i clean the grease off ?
You should talk to the guy that installed it and demand your money for labor back!having an issue it still slipping off , It slipped off luckily it was in 'park' at the time... should i clean the grease off ?
