help column shifter broken stuck in DRIVE gear
B
BG1988
Another WTF Brent thread lmao. Or lame-o according to my buddy Jimmy. Which might actually be appropriate in this case. :lol2:
what if you can't get the part and what am i going to do?? go under the car every time I need to shift it??
B
BG1988
Nah just scrap out the car, it’s done in that case, right? It’s not like there might be another solution. Come on man you’re killin me!
i'll try to install it later too hot right now i got it
someone actually stole the package but returned it after wards they ere to disappointed nothing great was inside..
B
BG1988
installed in 2min shop wanted to charge me 160$$ for 2 hours of labor
what kind of shop? I could see a place charging a minimum fee for putting it on a lift, etc but 2 hours is pretty excessive
:nolol: but I already did that for free :rolleyes: , you didn't tell them you had already "rigged it" to work and that's how you got there?
B
BG1988
It shifts nicely and shifts like a brand new car does.....
B
BG1988
well they could have earned a new customer, I was planing on having the Aux transmission pump, new fluid and a double filter change to transmission(has two filters) ... i just had diagnostics done a month ago it came up inconclusive... but the aux pump is the "typical" suspect esp in the 2008/09 model..
just so i can keep up on the fluid changes because its all ready been like 25k since the last fluid change it was changed at 80k or so i guess and it's at 105k.....
i was going to have the rear end changed as well(oil)..
B
BG1988
having an issue it still slipping off , It slipped off luckily it was in 'park' at the time... should i clean the grease off ?
ya it doesn't need any grease, clean it real good and be sure you have it installed properly, I have one on mine it's never came off
You should talk to the guy that installed it and demand your money for labor back! o_O
Towmaster
