Headunit Install Questions
rgaffney
VA/GA
Just winging the install with my room mate, need help.
In this photo...
1) How do you remove the clip on the left? I yanked a little but didnt want to break it off.
2) is the cord on the right the antenna? Do i need this?
m3mphi57
In this photo...
clip should just wiggle off wiggle back and forth and pull on it should just pop out and the the other is antenaa and if you want to listen to radio then u need that one
vatahoelt
NoVa
i think you have to press those two tabs on the ends and then wiggle it back and forth like m3mphi57 said.
rgaffney
rgaffney
VA/GA
So all I need to do is cut the connector on the left and splice it with the connector that came with the new HU?
vatahoelt
NoVa
it depends. do you have bose? if so, you'll need an adapter which goes in between that plug and the wires from your new HU
rgaffney
rgaffney
VA/GA
I do have bose, and I found the adapter just haven' bought it yet. Once I have that adapter, it's plug and play correct?
rgaffney
rgaffney
VA/GA
I held back on cutting and ordered the GM harness
rgaffney
rgaffney
VA/GA
So the guy at the local car audio place mentioned me needing to connect the unit to the parking brake. Do I really need to do this? It sounds like this prevents me from watching dvds while I'm driving, but I would like to do that anyway.
bsims3996
alabama
car audio shops are suppose to hook up the parking brake wire. (legal reasons) depending on the brand HU you have some of them you can just hook the parking brake wire up to the power wire , some you can get a bypass module from ebay. but either way it can be bypassed
rgaffney
rgaffney
VA/GA
It's a sony xav-60
I dont really care about doing this unless I have to. Would the HU not work if i didn't wire it to the parking brake wire?
m3mphi57
It's a sony xav-60
is this a in dash tv if so u can use a 12v relay and by pass so u can use the tv any time
rgaffney
rgaffney
VA/GA
This keeps getting more and more expensive.
So if I don't connect to the parking brake or use a relay to bypass that my headunit will not function at all?
I ordered the GMOS-04 adapter and I was hoping that was all I needed but I don't get that impression anymore
nytahoe
"Tha Butcha"
new york
u might just have to ground the green wire and thats it. dont know sony that much.
stayedge
Mineral Wells,TX
your head unit will work just connect it, i have an indash and didn't even have to ground the parking break wire and it plays dvds while i drive
just connect it to your wire harness and dont ground your parking break wire unless you need to.
(*not held responsible for tickets*) lol
m3mphi57
no buy a 12 v relay and make sure the pins are 85 86 87 and 30
86 87 get grounded so do a loop ground take 86 and 87 connect together then one wire out and run to ground thats grounded to radio
85 blue remote wire
30 goes to e brake wire
any questions let mek now and ill try to send pics if needed
glazar
