Halo headlight assemblies
fiatdale
Houstons Best
Houston
I have a set of Eagle Eye headlight assemblies complete with Oracle halo rings. The rings are 6000k white. No rock chips, scratches or blemishes on the lens. Completely sealed with no leaks. I've had them on the Tahoe for about 3 months with no problems, but a lot of head turns! Asking $175 shipped to lower 48.
soulsea
Bar
It depends if flatdale had them spliced to his parking lights or if he has a dedicated switch for them ... if it's the former it's an easy swap, if it's the latter it's slightly more difficult.
fiatdale
fiatdale
Houstons Best
Houston
Halos are wired into the DRL harness. So it's plug and play. Just replace your stock headlight assemblies with these and you're done.
Light output is the same exact as stock.
My grille is the factory LTZ grille with the surround painted black.
GalaxyBlackEsky
BlackedoutLT3
MD
This is a good deal. If I had the old Tahoe still I would have prob picked these up.
fiatdale
fiatdale
Houstons Best
Houston
They definitely turn heads because they are stock housings, not stupid looking aftermarket ones. Oracle Halos typically run $200. Aftermarket OEM look housings run $150. Its a deal.
Jimmyp19
NH
When you opened them up to add the halos what did you seL them back with? Would they be able to be opened again to paint?
fiatdale
fiatdale
Houstons Best
Houston
Sealed them back up with Butyl. Should be very easy to bake and open back up again without issues.
fiatdale
fiatdale
Houstons Best
Houston
Selling just to switch it up. I really want to retro projectors in, don't want the halos anymore. Absolutely nothing wrong with them, just want to switch it up.
Blazed
Accepting Donations
If they were ccfl I would know a guy who would want them but they are SMD aren't they?
Btw I told you before but you're grille combo is sick black/chrome/2013bowtie
fiatdale
fiatdale
Houstons Best
Houston
Yes they are SMD. From 10' away they do look like continuous ccfl.
johnsonwillie199
