Gauge Cluster lights lightly flickering
diezelraccoon
I’ve noticed lately on my 03 Tahoe the gauge cluster lights have a very faint light flicker at night. Narrowing down electronic issues is not my forte. Any help resolving the issue would be great.
S33k3r
Dallas, Texas
The clusters are a common failure point on these vehicles, given their age. More than likely you have a weak connection on the cluster board itself; could be solder that is breaking loose after all these years. There may be YouTube videos that will enlighten you on this, but there are typically folks who commonly do these repairs who will be local to you.
Moderator
People's Republic of Colorado
I would suggest monitoring the voltage at, say, an interior power outlet to see if the body is getting stable voltage. You may not see voltage variations in other lighting, but if not just a cluster problem I would think it would show up in headlight lighting. You could substitute a like cluster for comparison.
Have the battery load tested at an auto parts store. Also have the alternator tested for correct and full operation.
If the main battery cables have never been changed or are in questionable condition, consider replacing them. Loose or dirty cable connections can cause this, too. Do a "voltage drop test" to confirm good connections between the battery and the body.
spectol
