Gas pedal
DenaliDrive
Hey y'all,
Is it there anyway to adjust the pressure of the gas pedal? It doesn't require much pressure, which results in movement while going over rough roads. Car & Driver review had the same issue when first tested.
Hey y'all,
what year/make/model are you talking about?
D
DenaliDrive
Apologies for the incorrect section. The model is a 2003 Yukon Denali
Sam Harris
Texas
My ‘03 is like this as well. It’s a bit annoying, especially considering how loud my exhaust is with these PRC heads, but I just live with it. Not a big deal.
B-train
That one is drive by wire. There isn't really a way to increase the feed back - the pedal spring is all internal. Maybe a newer replacement may have better built in feel
depends, 03 was a year that some have a cable and some do not I don't know the specific range though. same for clutch fans/electric.
then in 04/05 (i think) the alternator pins changed on some 4pin/2pin
this is all based on member feedback of what they have or had
my 03 was drive by wire... clutch fan 4 pin alternator
the wifes previous 04 had a clutch fan and 4 pin alternator
then her 05 had electric fans and a 2 pin alternator
there are some mixed with all of the above pretty much
D
DenaliDrive
Thanks for the information, guess I'll try and use cruise as much as possible :)
Matthew Jeschke
Sahuarita, Arizona
I have HP tuners... my truck is a cable which is what I bought HP tuners for...
There is a page of calibrations for the throttle by wire. My C5 vette has throttle by wire and works AWESOME. It is definitely a better system than the cable IMO. Sorry to hear yours is too sensative.
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Pedal commander and set it to eco mode?
Matthew Jeschke
Sahuarita, Arizona
My Corvette was professionally tuned... He reconfigured all the throttle by wire stuff. It works SO awesome. I'm tuning my Tahoe by myself but I don't have the electronic throttle on the Tahoe.
Here's an idea of what settings are in the computer for your electronic throttle. I'd venture you could dial back the sensitivity. Although, it says modify at your own risk, but I'd think a tuner out there might know all that figures out better than I.
FYI ~ There are two modules on these older setups (not sure about new stuff). The first is the PCM. The second is the throttle controller / computer.
There's tuners in most major cities. Maybe somebody on the forum here knows of a reputable one in your town who could dial back the the throttle sensativity?
BatsTDK
Orange County, CA
I don't think the problem is that the throttle is too sensitive, it's the physical spring on the gas pedal. There's no "dampening" or whatever. Causes it to be springy/bouncy. Especially when going over bumps or rough road. Your foot keeps bouncing the gas pedal. Think of it like a car with blown out shocks. Bounces over the bumps. I've gotten used to it though and kind of figured out how to keep my foot steady.
BadDaddy2003
