Gas leaking
Marbor
Chicago, IL
alright here's another one, so I go to the gas station to fill up and low and behold once full I see gas leaking onto the floor.
What the heck, so what should I check? I know its a plastic tank because I replaced the fuel pump and put all new part to include gasket and ring. I made sure the ring locked in and turned all the way. What else can I check? I parked on the street for the night so I don't have gass all over my drive way in the morning. Hopefully no one tosses a cigarette while passing and burns her down fingers crossed.
97 tahoe LT
Danny3737
Is it leaking near the tank or by the engine? Did you try to top it off after the pump shut off?
Marbor
Marbor
Chicago, IL
Leaking by the tank just under the rear pass dr. No top off idk I put $52 and had just under .25 in the tank, but gauge shows full.
exp500
Hopefully it's just a vent or fill line leaking, maybe even pressure line, Hope it's not the lock ring area. You know why.
Marbor
Marbor
Chicago, IL
Dont think its a line because car has no leak when on and yea lock ring means dropping tank while full is a bi#&^
Marbor
Marbor
Chicago, IL
as an update truck was still there in the morning no problems. No leaking but left a nice black stain on the city ground not my driveway. Anyhow instill have a full tank and from the looks of the spot I'm guessing its something simple hoping just an old fill line or return.
iamelrl
just recently had this happen after buying mine. Had to replace the gas tank
YukonGTmaster
2 Door w/ Barn Doors Club
This happened to me, when my wife borrowed my truck with a full tank of gas in it. The needle on her Van was oriented a different way, so she decide to help me out, and “Fill” the tank. It started leaking at the Fuel Tank seams. Replaced the tank, no more leaks. Twisting the rusty fuel line fittings loose was the worst part.
CKendrick
