grouch
- Joined
- Jan 23, 2019
- Posts
- 3,537
- Reaction score
- 12,911
I have a problem with my '93 GMC C2500 RWD. The steering began to wander going down the road. I took it to a local tire shop for the front end to be checked. They told me the steering gear, idler arm and pitman arm needed replacement. They were worn and the gear was noisy to out they came and new parts went in. While I was under there, I grabbed the tie rods and they were tight. Took it out on the road and the wander was still there. No noise, but enough wander to induce the pucker factor. I stopped by a friends shop and checked the front end while the suspension was under load. Under droop, the tie rods were tight but under load, quite loose. All 4 tie rods and even the adjustment sleeves were replaced.
I went to a different front end shop for an alignment. At about 50 mph, the wander comes back. Now, the tires in back are new. I have 2 pairs of tires to put on the front. The pair I was using were swapped for another pair of used tires I bought for spares. The ones I had on the front were on it when it came out of a barn so they are at least 10 years old.
Both shops said the ball joints were good. I've had bad ball joints before and they didn't feel the same way. I've even checked the rear shackles in case one was cracked.
Anybody got any ideas? I got a newer, 4X4 truck so this one is for sale. If it needs tires, it will get them. I just don't want to throw money into a truck I'll be selling.
