Front End Noise
David Smith
Savannah, GA
2001 Tahoe 5.3 4x4
So I recently noticed some noise coming from the front end of my Tahoe. It sounded to me like a wheel bearing. The previous owner claims they just put new ones on (a little over a year ago now) and I already had to replace the passenger side. It was making a VERY loud noise. From about 20 all the way to 80. Did not stop or let up. It was a CONSTANT roar. Had a shop tell me it was the worst that he had ever heard.
So my best friend works at a junk yard and I got a used wheel bearing from them. I thought, hmm, what are the odds of this one being bad as well. Since its only a 45 min job to swap them, it was worth a shot to see if it fixed the issue.
I swapped the wheel bearing and cross rotated my tires while I was at it. When I pulled my wheel bearing off, I spun it and it sounded terrible, so I figured that it was the problem.
Now that I have the new (to me) wheel bearing in, the sound seems to be exactly the same as the old bearing.
So I have 2 questions. How likely is it that my front carrier is making this noise? The previous owner also claims that they had all fluids changed around the same time as the wheel bearings.
Also, what brand wheel bearing would be best recommended for a 4x4 lifted, bigger tire size Tahoe?
Thanks in advance for y'alls help!
HiHoeSilver
Away!
Chicago
2001 Tahoe 5.3 4x4
I don't know about the carrier, but the best bearings are Timken by far. Rock auto has them for $100 ea.
David Smith
David Smith
Savannah, GA
I was listening more today, and the noise does not change pitch. It is pretty much the same pitch through all speeds, but the noise gets faster. It is not a steady hum. I can't really post a video because my tires are kind of noisy and you probably would not be able to hear the noise.
It is more like an on off thing. I don't know how to describe it. Instead of a steady hhhmmmmmmmmm that changes pitch with speed, it is more like a woo woo woo woo woo. Like I said, the pitch stays the same, but the woo woo gets faster as I go faster...
Thoughts?
HiHoeSilver
Away!
Chicago
Thoughts?
That sounds like it's rotational. You said you can make the noise by jumping on the bumper? Have you checked the wheel for play side to side and up /down while it's off the ground?
M1Gunner
Gainesville, Fl
That's a bearing noise. If the frequency of the woo woo woo's gets fast with vehicle speed and not rpm, then it's not engine related. It will be a bearing that is from the output shaft to the wheels.
Try swerving left to right and listen for the intensity of the woo woo woo lol to change. Swerve left and it goes away or softens its he right bearing vise versa. If it doesn't change, it'll be something in the rear. Output shaft bearing pinion bearing rear axle bearings etc.
David Smith
David Smith
Savannah, GA
No, I never tested jumping on the bumper. I have not checked for play since I just put the wheel bearing on a few days ago.
In my personal experiences, bad wheel bearings have always changed pitch the faster you went. I am not sure if this could still be the case or not. I will probably be digging into it a big this weekend to see what I can find...
HiHoeSilver
Away!
Chicago
Sorry, confused two threads. I'm with @M1Gunner on this one.
David Smith
David Smith
Savannah, GA
I will try the swerving thing. If by frequency you mean how often then it does change. It does change with speed, but it does not really get any louder. It is also not similar to the noises that a mud tire makes (the faster you drive, the higher the pitch is). It is just as loud at 20 as it is at 60. The pitch never changes, but the woo woo noise gets faster the faster I drive...
HiHoeSilver
Away!
Chicago
Then it's definitely rotational. A bad hub/bearing assembly can make some whacked out noises, for sure. My last one screamed like a banshee on and off with no rhyme or reason.
M1Gunner
Gainesville, Fl
If it was your carrier bearing(s) you would know it brother. It would throw off the backlash of your pinion and ring gears and every where you went you would think there was a fire truck following you lol.
And that lil woo woo woo of a wheel bearing ain't what I'm referring to either.
David Smith
David Smith
Savannah, GA
After weaving all over the road yesterday, I found that the noise goes away if I swerve to the left. New wheel bearings it is!
David Smith
David Smith
Savannah, GA
Timken for sure. Also, at Rock auto they are cheaper than those by $5, plus there is a 5%off code in the vendor section.
I am going to be ordering them in the next few days and putting them on next week. Next step will be finding my oil leak lol
M1Gunner
Gainesville, Fl
Awesome, RH wheel bearing is the culprit! And Timken is hands down first choice for bearings.
Keep us updated man!
koomie98
