From one problem to the next.. Broken ring gear teeth.
MattysHoe95
MattysHoe95
So, I got the gears, Install kit etc. I am wondering why the yoke seal doesn't fit and it seems the front pinon bearing will not slide on. I assumed I had an 8.5 rear diff. I measured the damaged ring gear and it turns out It is an 8.25. I thought only the front diff uses 8.25? guess I will be returning some parts UGH.
TCUSA
