Fosscore
- Joined
- Apr 16, 2014
- Posts
- 10,860
- Reaction score
- 19,725
Still looking badass!!
Truck looks real good. [emoji108] Love it. Do you have it set at 4/6 or higher?![]()
Still loving it lowered [emoji1305]
i got my 2013 on 24"x10 295/35/24 tires, and i have a rear end excessive bounce issue, did you have any of those same problems and if so how did you fix it. i got 2" spindles on the front and 3" coils in the rear. I shaved the bump stops and that helped a little. The shocks are stock and on shock extenders. Do you recommend putting in a lowered shock or coil bladder295's and very slightly on the drivers side, getting it aligned today. It rides great!
You probably need to do the free travel mod. Your rear bump stops are probably hitting.View attachment 73467
1) what kit did you use?
2) stock shocks not the greatest
3) did you change the rear endlinks
4) i would for sure do shocks/endlinks and free travel mod i sell all
I have a MCGAUGHYS 2/3 KIT. with stock shocks on shock extenders. I didn't change the links. I did trim the bump stops. I think that's my issue, the shocks. I ordered BELLTECH'S REAR LOWERED SHOCKS meant for my application with a 3" drop. I'm gonna try getting rid of the shock extenders and getting the shorter shocks back in their intended brackets under the axle instead of down and out.
With the Tahoe being lowered with Mcgaughys 3" springs, the AIR LIFT kit I ordered had to be a special order. Air Lifts websites says a actual measurement of the horizontal distance of the inside of the coil and a vertical so the right sized bladder bag is inserted. And it has to be done when the normal ride weight on the springs. So when the stocks springs were taken out, the standard AIR LIFT BLADDER BAGs kit for my Tahoe wouldn't work. After I get it installed and test driven, IL be sure to post a update with pics and kit info and hopefully if it worked or notVery interested in your results. Please post your progress.
Interesting that the standard bags won't fit
I was hoping to use my air bags with a 4" drop in the rear
Oh mines all stock atm . I'm thinking ahead that's allWhich springs so you have. I have the airlift info on my vendor section in dimensions.
