FINALLY 55 WATT 12000k H.I.D.s
Oklahoma
After waiting for 23 days of backorder my hids are installed. They are DDM 55watt 12,000k. In the head on pics there is a little tint of blue, but while driving the lights are white. Which is weird. I bought the 12000k bulbs knowing that the color would washout a bit. But LOVE the way these look.
Modded
That Guy
That looks HOT...No way thats a 12k though, doesn't look blue enough in the pics, my 6k bulbs are that color?
killer20072001
Oklahoma
Thats what I was thinking but hey whatever. These pictures dont do justice. These 55 watts are crazy bright. Everybody around here has 35 watt kits. I was thinking my friend thats in my sig pic has 10000k 35 watt might switch out bulbs and see if they are more blue in his. I wanted a little blue but also knew the color would wash out a little bit. Thats why i got the 12000 thinking they were gonna look more like 10000, but look more like 8000.
puckhead
CO
Looks good! That 55 watts really fades out the color
killer20072001
Oklahoma
BTW andy got your pm he is still thinkin on that amount for the muffler.
---------- Post added at 12:38 AM ---------- Previous post was Yesterday at 11:49 PM ----------
IDK after driving to the ATM in the middle of the night I might be convinced that these are 12000k. They are deffinantly not as blue as I wanted but they are just a little more white than the wifes 35 watt 10000k. I think what makes em look so white is just the reflection off of my house and garage. The spread on these are crazy. Like if im parked directly next to my porch its like the porch light is on. Maybe also that my headlight housing is black. Never thought of that.
thehoe92
fo sho
The916
you have to remember that 55w washes out the color fast when it goes up the kelvin scale
it will preserve color towards the bottom of the scale
you can always buy more sets of bulbs, they are only $15
but nice choice on the HID's :)
so many people give me shit for running 12k's but I love the color AND brightness!!
DenaliAK
Colder than you
Alaska
As mentioned, the 55w power really kills the color. They are still fairly blue, though.
I can tell you from your pictures that you need to adjust them down. I won't lecture, and it actually has a pretty decent cutoff for a reflector, but they are pointing too high. You're going to blind people.
Looks pretty sick, though!
killer20072001
Oklahoma
I thought my cut off was pretty low considering how far away I was parked from the garage. The only time the light was right in my eyes was when I was down on one knee. Not geting mad at you Scott. Im probably not gonna adjust them unless I start getting flashed by alot of people. Then i'll turn them down.
killer20072001
Oklahoma
would 55 watt hid's be to hot for my foglight housing?
if so i'll do a 6000-8000k 35watt in the fogs
Ya these things are HOTTTT I can stand in front of my headlights and feel the heat if i would ever do hids in my fogs i would go 35 watt just to avoid the hassle.
DenaliAK
Colder than you
Alaska
It was mainly the one shot against the side of the house that makes it look like they are too high. You can't tell from pics of the front because they are so bright cameras have a hard time taking accurate pictures. But, at least with mine, I get flashed unless I have them just below a standard door-knob height. Hard to tell if you're on level ground, too...if you're tilting up even just a little bit, it'll throw things off.
But yeah, don't worry about it unless you get flashed a lot. Like I said, it looks sick!
FWIW: I have 55w in my fogs and have had no issues in six months. But, it's also been cold out. That could change with the warmer temps if I run them much. Luckily, it's light all the time here in the summer, so I probably will barely use them until August/Sept.
killer20072001
Oklahoma
Well on my garage its about where the handle is. I never thought of my drive way beeing un-level. My driveway is horrible. It is in no way level.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
You also have real reflector fogs. Not plastic boxes with a light bulb in it like the Tahoes. ;) That helps a LOT with heat issues.
DenaliAK
Colder than you
Alaska
True enough. I wouldn't run 55's in those little rectangles they call lights on the Tahoes....
TheUnscented
Is that the stock Yukon housing or did the kit come with new reflectors?
Buford bubba
