fact bose sub
Nortex
Is there a factory bose sub that goes in the rear cargo area? Will it work if I had the reg stock sub? Any part numbers
slowstang305
Miami
I have an 8in kicker in the trunk of mine. I went with 2 12s instead though, quite a bit more bass.
N
Nortex
I just need alittle bass. I dont liten to rap just rock and country
andrewmoore13
there is a factory bose amp and sub but i hacked my sub enclosure up. :(
NorCal Nali
Granite Bay
I'll sell you my stock Bose subwoofer and Bose amp. Just let me know and I'll pull it out.
01yukonslt
need more deebeeeez!
Spokane, WA
if you have no sub at all the 01-02 had a rear sub if it came with the premium system not sure if bose was back there.. anything newer they moved the sub to the center console. what i would do is get the rear plastic or cut yours and get a good 8 inch sub with an amp and you could easily hide it all behind the plastic on the drivers side.
---------- Post added at 02:16 AM ---------- Previous post was at 02:12 AM ----------
if you wanted my enclosure i would take it out and ship to you for fairly cheap also since i got an all new system and eliminated the 8 anyways.
abladeafficionado
I have a 2001 Denali and it came with the Bose sub that's in the rear cargo area on the passenger side behind the plastic panel. It's decent, nothing like a dedicated high powered substage, but it's good enough for me since I can't afford to sacrifice any cargo area.
Later on the Denalis moved the sub to the center console, 2003 or something like that was the first year of that.
N
Nortex
Does the denali sub and amp just plug and play? I have the fact sub but I blew it
kses123
kses123
Raleigh, NC
No, it wil not be plug and play. You can get a new speaker for your sub under the console. It is fairly cheap. In my 2001 Denali, I had the factory Bose sub and amp in the back and I got the 2003+ sub that is in the console and I wired that sub in. It sounded pretty good!
N
Nortex
damn , I will just try to find a sub and amp combo for the stock location
Rpprvnce
Memphis
I have a 2002 yukon SLT it has the sub in the cargo area but it is blown and sounds terrible any ideas for replacing it? Or should i just disable it? I have two kicker CVRs in my truck and thats more than enough bass for me! Also does this mean i have a bose system? If so, I am having a problem with static in all of my speakers.. I have a DD pioneer installed in my truck
Danzigman
Galveston, TX
So in my '05 Tahoe with the bose system I should have a sub in the console or was this just on Denalis? I Have hade it for about 2 weeks and just noticed the rear speaker looking area yesterday.
kses123
kses123
Raleigh, NC
2000-2002 There was a sub in the rear for most models. Bose only came in the Escalade/Denali those years and had a specially designed sub.
a4edwin
ny
i've had my 03 hoe lt for 3 days and i have no bass my door panels say bose and i have the subwoofer looking panel in the rear but the grill looks sealed where would my sub be and how can i check if its the amp or the sub thats dead?
kses123
kses123
Raleigh, NC
That's where the sub was in the 2000-2002 models. Your subwoofer is in the center console. Under the the front part near the dash.
[/IMG]
briannorris
