Escalade Protection
BAWLin in WI
WISCONSIN
Got a couple questions
2009 Escalade Base
Just bought not long ago. I have a extra set of wheels tires I put on that i had on my Silverado. They're 18" wheels but the tires are more aggressive all terrain tires that i want on for the remainder of winter as they are better in the snow than the street style tires that came on the 22's.
My questions are regarding additional protection options for the vehicle itself. The secondary set has a little more offset and wider tires on top of that.
Im wondering if anyone has either husky liner, weather tech, or other drill-free front and rear mud flaps they'd recommend. I read the husky liner ones aren't compatible with the 22 inch wheels. I'm wondering if the weather tech ones are the same case. I'm most concerned about the fronts.
Another thing i had heard of from someone is clear stick on rock-guard type protection. Is anyone familiar with such a thing? I've seen some type on cab corners on some vehicles I believe but not sure if there was a good product i could get to help protect from rock chips and such with the tires sticking out a little wider.
Thanks
Sent from my LGUS997 using Tapatalk
kbuskill
NE. FL.
Any decent vinyl shop should have clear bra which is what you are talking about.
It is a fairly thick clear vinyl that protects against rocks and other debris.
RRWW
I have the weather tech front and rears. With oem 22's and power running boards. Fit is fine. I lowered the truck 2/4 after this pic and had to very slightly trim the fronts. If you want any more pics let me know.
BAWLin in WI
BAWLin in WI
WISCONSIN
Do you happen to have a pic of closer to the fronts? I may just go with fronts. I've got after market wheels on right now that are a little bigger than the factory 22s that i will likely be running again once weather starts cooperating
BAWLin in WI
BAWLin in WI
WISCONSIN
I think I'm going to go for it and order a set of the weathertech fronts for now
worleytrev93
