Stopped at the gas station did my thing got some gas and checked the oil dip stick , it was bone dry or was it a false reading??
I added 1/2qt to it as not to over fill the crank case (just in case of error reading) i'll check the morning
did not hear any abnormal noise from the engine.
AFM seem to shift between v4-v8 smoothly.
it did not trip the low oil sensor or Low Oil Pressure PSI seemed fine with in my engine "normal range"50-75PSI(as seen on start up)
the only thing i changed was 1qt 0w30 + 5qt of 5-30 on the last oil change.. before i was using only 5-30w 6qt
another engine bites the consumption dust?
