Engine just stopped running.....
Mig
I have a 99 Yukon 4X4. My wife was sitting at a light and the engine just shut down. Have all electrical working, and ignition would turn over the motor but would not restart. After towing it home and letting it sit a while ran a code check on it. A 171 code showed up, cleared the code, then the truck started right up. Totally confused. Only thing I can think of is vapor lock because it was about 102 degrees outside on top of the engine heat generated. Any suggestions?
M
Mig
Just stopped running.....
SunlitComet
OBS Jedi-Do Good
unknown at this time.
:welcome:
If you don't see a chart labeled P0171 fuel system trim lean bank 1 just below let me know I I will refresh them for you. The picture and charts change after a few hours.
Powertrain Controls Diagnosis
156490266
170571109
166234174
78569746
78569747
Circuit Description
In order to provide the best possible combination of driveability, fuel economy, and emission control, the vehicle uses a closed loop air and fuel metering system. While in closed loop, the VCM monitors the oxygen sensor signal voltage. The VCM adjusts the fuel delivery based on the signal voltage. The long and short term fuel values, which a scan tool can monitor, indicate a change made to the fuel delivery. Ideal fuel trim values are around 0% (128 counts); if the oxygen sensor signal indicates a lean condition, the VCM adds fuel. This results in fuel trim values above 0%. If the oxygen sensor detects a rich condition, the fuel trim values will read below 0%. This indicates that the VCM is reducing the amount of fuel delivered. The VCM sets this DTC when an excessively lean condition is detected.
Conditions for Running the DTC
  • No active O2 sensor DTCs
  • No active TP sensor DTCs
  • No active MAP sensor DTCs
  • No active EGR sensor DTCs
  • No active EVAP system sensor DTCs
  • No active ECT sensor DTCs
  • No active MAF sensor DTCs
  • No active IAT sensor DTCs
  • No active VS sensor DTCs
  • No System Voltage DTCs
  • No active misfire DTCs
  • Throttle position less than 70%
  • Engine speed is between 575 and 4,000 RPM
  • The BARO greater than 70 kPa
  • The ECT is between 75 and 114°C (167-237°F)
  • The MAP is between 22 and 85 kPa.
  • The IAT is between 8 and 76°C (46-169°F)
  • The MAF is between 3 and 85 g/s
  • The vehicle speed less than 85 MPH
Conditions for Setting the DTC
The average of the short term fuel trim values over a period of 120 seconds indicates that a lean condition is present.
Action Taken When the DTC Sets
Important: To complete a trip cycle for the fuel trim diagnostic, the fuel trim diagnostic test must enable and run according to the above enable criteria and the conditions for setting. A trip is not considered complete until the fuel trim diagnostic has run by the VCM.
When the current DTC initially sets, a software flag indicating an emissions related fault sets for 3 trips. The flag will clear provided the lean condition is no longer present. However, if the VCM detects the conditions for setting the current DTC during a trip while the flag is still set, the VCM turns on the MIL (Malfunction Indicator Lamp). The MIL remains on during all of the subsequent trips until the DTC has been cleared by service or the lean condition has not been detected and the conditions for checking the fuel trim have been met for 3 consecutive trips.
Conditions for Clearing the MIL/DTC
  • The Control Module turns OFF the MIL after 3 consecutive drive trips when the test has Run and Passed.
  • A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles (coolant temperature has risen 22°C (40°F) from the start-up coolant temperature and the Engine Coolant Temperature is more than 70°C (158°F) during the same ignition cycle).
  • Use the scan tool Clear Information function.
Diagnostic Aids
If using the diagnostic tables does not isolate the problem, try monitoring the LT fuel trim and fuel trim cell while operating the vehicle under various loads. This may isolate the condition which caused the setting of the current DTC.
A condition that causes the DTC P0300 Engine Misfire Detected may also set the current DTC; conversely an extremely lean condition which sets the current DTC can cause a misfire at idle and the DTC P0300 to set. If the cause of the current DTC cannot be determined and the DTC P0300 is also set, refer to DTC P0300 Engine Misfire Detected. See: P0300
Typical Fuel Trim Values
The Fuel Trim Values table indicates the typical fuel adjustment values as displayed on a scan tool. Negative values (Rich condition) indicate that the injector pulse width is being decreased in order to lean out the fuel mixture. Positive values (Lean condition) indicate that the injector pulse width is being increased in order to richen the fuel mixture.
Test Description
The numbers below refer to step numbers on the diagnostic table.
2. A more negative value indicates the VCM is leaning the fuel mixture (Rich condition), and a more positive value indicates the VCM is richening the fuel mixture (Lean condition).
5. Visually and physically check the items that can cause a lean condition in order to determine the cause of the DTC being set.
---------- Post added at 03:22 AM ---------- Previous post was at 03:16 AM ----------
Keep in mind this does not usually stall a vehicle like an intermittent ignition component Or a crank sensor dropping out.
TallHoe 96 OBS
