Enable features/options BCM programming?
A123
Hello,
I want to know which options/features can be enabled by BCM programming?
I was looking around but couldnt find a thread on this topic...
Also, is there any place that can program BCM for CANADA other than White AUto and Media?
Hello,
They are the only ones I know of. If you have a Tech-2 or something similar and a subscription to ACDelco's TDS system you can probably figure a way to add some things.
kbuskill
NE. FL.
Hello,
Just curious why you don't want to go with WAMS?
Do they not ship to Canada or something?
A
A123
Do you know any features or options that are a good choice to be enabled?
Well, I believe they can alter the length of time the engine runs with a remote start. They can turn off DRL, which I think are off for you guys anyhow. They can make the headlights and fogs stay on at the same time too I think. If you have the wiring and modules, you can have them activate the heated and cooled seats, side blind zone alert, glass break sensor, tilt sensor if bad guys try to tow your truck, etc. Probably lots of other tweaks but these just came to mind.
kbuskill
NE. FL.
***Common Features/Requests Include:
Add Remote Start
Extend Remote Start Run Time
Fog lamps remain on with high beams
Removing DRL
Manual Headlamp controls for Export Vehicles
Manual Transmission Conversion
Removal of fleet speed limiter
Hyperflash fix for LED lamp installations
Delete features/hardware***
Hyperflash fix is for people wanting to use LED bulbs in the turn signals without getting the bulb out warning (flashing at twice the normal rate).
I'm sure there are other options available as well.
A
A123
Thnx for the ideas...didnt think about some of these..
A
A123
Add Remote Start
Removing DRL
Ya, I read this on their website. I want to get the hyperflash fixed as I installed LEDs
TiGrayMSM
