Emissions Modules refused to set (SOLVED)
LordWayback
So I presented to the mechanic with modules not setting after driving nearly 500 miles following the module instructions to a T i have the Secondary Air Injection reaction (required in California) but that module , Catalyst And the Evap modules wouldn’t reset. So what my mechanic realized was my ignition wasn’t shutting off all the way (battery was on the display where security would flash). And because it wasn’t shutting down all the way it wouldn’t set the modules. As soon as they did the ignition and drove it to shandon @ 55 mph (about 40 miles each way) and all the monitors set I hope it helps your guys emissions issues because this was a $20-100 part that costed $627 at the mechanic but you could definitely do and diagnose yourself.
LordWayback
LordWayback
I have more diagnostic information if you would want it I have tons of other random fixes like the power mirror switch problem I had, I also fixed my Overdrive problem but it’s a common and well documented repair I found it on YouTube.
mfinta
