Emergency help... Transmission
Drgracin72
I've got an 11 suburban, ltz, 4x4,towing pkg. Pulling a 3k lb trailer, and a loaded cab area. In Colorado, pulling up a pass. Truck down shifted to 4th gear, and felt like something popped, engine died. Temp was running 160ish before the pass, and got up to 200 when it happened. Any ideas? Truck will go into gear and pull forward, but feels like there is some hesitation. Thanks. Currently sitting on the side of the road.
Sent from my SM-N960U using Tapatalk
89Suburban
Bull in the china shop
SE PA
How many miles on it? Did you check your belts and hoses? Check all fluids? Any leaks under it?
So you think that this is transmission related? Is the engine idling ok? Can you crawl underneath and jimmy the driveshaft and check the u-joints and yokes?
Do you have any kind of scan/diagnostic tool with you?
D
Drgracin72
Sorry, service is spotty... U joi ts all good, no fluid, no warning lights...
D
Drgracin72
Belts, hoses, fluids all good. 135000 miles
ivin74
05 NBS Nali
Htown, Texas
Any noises while Idling? Go through every gear and advise if it engages. Does the 4x4 engage? Were you pulling on 4x4?
89Suburban
SE PA
Try shifting it manually through each gear? For ***** and giggles did you try backing it up and see how it feels?
rick9667
