Dropping the back more?
Getinyukinlower
Oklahoma
Hey guys, I got a 2002 Yukon a couple of months ago and have been customizing it a little bit. I put a 2/3 belltech drop with keys and springs then cranked the keys all the way down. The front sits exactly where I want it to but the back is way to high. Where can I find 4" or 5" drop springs for the back? Or can I modify the factory or after market drop springs I already have?
red02chevy
Lubbock
I'd recommend the Belltech trailblazer 4230 coils. They ride amazing and net the amount of drop you're looking for. I am running them on my girls 07 Tahoe with one coil cut off and the ride/stance is perfect. Make sure you remove the bump stop mount off the frame aswell to give you some travel
G
Getinyukinlower
Oklahoma
So I was looking at trying to cut a coil off the ones I have or the factory ones. But when I was looking at them to cut I thought it wouldt work because the cups the coils sit in. How do you make it work? But I will have to check them out! Thanks
red02chevy
Lubbock
there some holes in the upper spring pocket and I just put the end of one coil in there.
G
Getinyukinlower
Oklahoma
Sweet and that holds the spring in with no slipping or popping out? I will check that out and get it done if that's all I need to do!! Thanks
blueflamed03
Oklahoma
Tony told me to get the adjustable kit...then you can take it (up or down) where you want...
NORCAL SS
SUV SUSPENSION GURU
Those would be cool but I already have 3" drop spring on it. I need 1.5" or 2" more in the back. That's why I'm considering cutting them...
can you please look at the spring and tell me the part number you have on it?
G
Getinyukinlower
Oklahoma
Ok I got under there today and saw 5305-001 did some looking around on here and found out that they are 4"-5" drop springs? I put the drop brackets for the shocks on there that came with the kit. So I took the shocks off to see what it would be like and it sits at 32" even! Exactly what I was trying to do! Now just need drop shock those brackets are a joke!! Thank you guys for all your hard work and knowledge!!
dizhai
