Driver side heated seat not working
95escahoe
When I turn the driver side heated seat on the button stays lit up for a few seconds that shuts off, the pass side one doesn't have this issue, any ideas?
cmc76
likely a short in the heating element. over time , they just burn out. you can trace your wiring and look for any shorts. or just pull the seat cover, if the heating element is toast, it will be pretty obvious.
95escahoe
95escahoe
They make new ones I take it?
cmc76
yes, i replaced mine when i put in a new seat pad, heater element and seat cover.
if your seat cover is in good shape, just get the element. i believe Dorman makes one.
95escahoe
95escahoe
Thanks, na my driver seat bottom is shot has the typical wear from getting in and out was going to replace it anyways I'll just do it all at the same time
cmc76
i think there are some less expensive options, but i got mine from the seat shop. perfect fit and match. was the first thing i did when i bought mine.
95escahoe
95escahoe
I got my cover for my OBS Tahoe there fit great and great quality
adventurenali92
Big Bear Lake, ca
I ordered my element on eBay. It was fairly cheap. If you're gonna do the lower cushion you may as well do the heater element while you have it opened up. That's what I did. Its pretty easy. Unbolt the 4 bolts holding the seat in. And then once the seat is unplugged and out, the cushion has little plastic clips that clip to the bottom of the seat of rail. Once those are off the cushion will come off and the heater element is right there.
Drewphil
