Driver master window switch
cbman18j
Savannah, GA
Tuesday my drivers window on my 07 NNBS with DL3 mirrows wouldn't come down when I pressed the switch. No clicking or anything. All other functions work except the drivers window. I jumpered power to the motor and the window motor operated normally. I was thinking my switch was bad then Thursday out of the blue it worked now today nothing. Is this indicative of a bad switch?
joshcarl
Woodbine, Ga
i had a similar issue with a rear switch. take the assembly out, and disassemble it down to the contacts (small copper pads where the buttons interface) and clean them with a pencil eraser. worked like a champ.
cbman18j
cbman18j
Savannah, GA
I will give that a shot. In order to get to the contacts I need to remove both circuit boards?
joshcarl
Woodbine, Ga
sorry, i don't log on here too much. if memory serves me correctly, you only need to remove the top of the switch panel.
burban2007
I had same problem on the rear switch as well. Same thing, contacts were the issue. Easy fix
Sent from my SGH-M919 using Tapatalk
montanaboy65
