door master switch programming
anarky321
bosch MDI2 and an SPS2 subscription from ACDELCO is all I need to program this right?
be sure when installing the techline software run (even) the browser and all clicks will be "right" click first then select run as administrator, otherwise your going to have problems and even then set aside a couple hours to get all the software installed and updated before you can even start to program. even running as admin it may take multiple tries to get it fully installed. once the software is all installed the actual programming part goes smooth.
Dh1280
