DJM Trailblazer 5 inch plus Drop springs Review
prosts1003
I already have the mcgaughys helper bags but those things don't do anything for the stock springs I'm hopeing when I do drop it they will help but right now the truck is getting two-tone paint then I need to look for some wheels before I do the drop
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
when you lower it yes will help much more
mrtrill
ATL
interesting, I learned more in a few posts than anyone' shop I went to inquiring about lowering my 2002 tahoe. im gonna have to come n here more often.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
matt since you've been riding in it what did it settle down to. I know you have 305 40 22 so are you at 32.5 from ground to fenderlip? I know after 75 miles of driving your at 32.75 but just seeing if it went lower since then.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
when you've been lowering the nbs tahoes since late 99 in over 10 years you learn a lot of stuff and im glad to pass the info along.
ghost
Senior Member
sorry if its been mentioned in the thread already but i skimmed throught it and didnt see.. what all do you need to run these springs? My current set up is 2" spindles and i bought some used eibach 3" springs from my buddy for the rear, problem is my truck looked raked so i cut about a coil n a half off and its kind of closer to level but not quite and it rides like doo doo.. help me out
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
ghost if you only have the front spindles all you need is the 3 inch rear belltech 3-4 inch adjustable kit with shock extenders. Ill pm you
Physh1
Just got my drop done today. Got everything from NorCalSS. Install went smooth except there was a small issue with the front shocks...
Good thing to know...the stock shocks still have a little travel on a DJM 3" front drop.
Overall, I did this today...
3" DJM arms...
TB drop springs...
DJM rear hardware kit...
BellTech F&R sway bars...
BellTech rear shocks...
KYB steering stabilizer...
After getting the alignment done the truck rides great. DJM front shocks are on the way...the stockers do for a pinch but they're not gonna last.
Awesome setup...I actually want to go a little lower but I'm going to let everything settle in and see where it sits. Here are a few pics....sitting on 22" Boss 330's with 275/40/22 rubber.
Cameron
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
yah ill get the fronts out to you on monday.
Juamgv
