Demolded
Brose
Cordova,TN
I went ahead and pulled the trigger and demolded the Yukon. It was fairly easy now all I need to do is wash, clay and wax.
2 E L O
Omaha, NE
Looks great! I think the silver birch trucks look especially nice without the moldings....but I may be a bit biased.... :Handshake:
Now you just need to debadge!!!
deangrell
Can you get a wider shot of the truck de-molded? I MIGHT do this later...
B
Brose
Cordova,TN
Sure I will post one tomorrow. It's all dirty from the salt and snow right now. Thanks I'm definitely getting ready to debadge it!
Mykon
oklahoma
let us know how it goes ..id like to do the same but afraid of scratchen it lol
KMeloney
Scratchen? Did your spell check just blow a fuse? lol
Use fishing line and heat, and there's almost no way to scratch anything. Just be sure that when it comes to the hard pieces with edges (like the individual letters, and the Flex Fuel badge) you don't get most of the way through the backing then PEEL the item back. If you do, you run the risk of digging the edge/corner of the piece into the paint. Take your time and get all the way through the back of the item so that it comes away on it's own.
bauer4567
Allentown, PA
"I debadged my car. Is it the same process to demold?"
Yes. Heat it up a little bit, and saw it off with fishing line. Then I recommend a 3M wheel just like many others here told me about... Goes so easy like this! There are numerous threads here about it... read around, it is a pretty easy mod.
iggyM
