Deck Accessory Power Issues
staticuky
I have installed a new deck in my 2003 Tahoe. I clipped the factory harness to wire up my new deck. I have a solid voltage reading across my Constant Power (Orange 12v) and a solid reading to ground across my Ground. My issue is that I have no voltage drop across my Ignition line. The only switched power source I can find is the dark green line going to the AC controls. This works, however if I turn my air on the radio turns off.
For now I have hooked the system up so that the deck's switched power is a constant power from the factory amp. It works however I have to turn my CD player off every time I get out of the car, and I'm not sure the circuit is dead when the car is off at this point.
Is there another known wire to clip into or how can I create a circuit that is off when the car is off for my Accessory line?
Thank you all
TnTahoe
TN
you should be able to pick something up from the fuse box
S
staticuky
Do you have any recommendations on how to do this?
Am I running a physical wire to the fuse box to add this in?
S
staticuky
Okay I have done some research now that I know I want to go to the fuse box, I think I have the solution. Thank you all for your help. I will continue the thread if something goes a miss.
m3mphi57
y did u cut the wires all u had to do was go to ur local audio store ans spend 20 bucks for a wiring harness.:emotions122:
TnTahoe
TN
they are less than that but for what its worth i wish i hadnt spent anything on the harness, you're basically using that harness for three wires (power, acc, ground)
TallHoe 96 OBS
