Cutting the 5305 for 5 inch plus drop
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
Done this many times on guys trucks over the years.
With the springs installed you will see 5 coils touching you can cut dead coils and will not change the ride. MAKE SURE YOU CUT THE SIDE THAT THE COILS TOUCH!!! NOT THE OTHER SIDE
Cut first 2 loops
Above cut will drop the truck about 5/8 to 3/4s. Remember if one side is higher ALWAYS CUT FROM THE HIGHEST SIDE FIRST because it will bring down the OPPOSITE side also. So of pass side is higher cut Above from that side first put back in and test to see if drivers side needs to be cut.
Tahoewhat
Ballin' on a Budget
TX
Thanks for posting this up Tony. I have these and was contemplating on cutting them or not or just getting the tb springs.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
no prob im going to cut another 1.5 loops tomm on my wifes tbss. Im testing them on her truck also since no one really uses the 5305 on the trailblazers.
Tahoewhat
Ballin' on a Budget
TX
How much would this drop my tahoe, by cutting it. If right now im at 32 all around on a 285/50/20.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
depending on how much you cut up to 2 inches.
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
just finished up another truck today im hoping owner shoots me pics.
4 inches in front via djm control arms
6 inches in rear via 5305 Cut 2 coils with djm hardware kit and belltech shocks
tbss replicas on 285 35 22
Truck still rides nice but going to add the helper bags when he loads up.
with 2 coils cut you still have 2 more dead coils you can cut if you want to get lower.
Tahoewhat
Ballin' on a Budget
TX
Is it a truck or Suv? Either way hope he sends you pictures. Interested in seeing it w/ the rear springs cut.
When is a C-notch required? For instance on my 05 Tahoe. How low could i go w/o having to notch it. Im on 275/50/20 tire
NORCAL SS
NORCAL SS
SUV SUSPENSION GURU
Supporting Vendor
was a brand new 2012 tahoe.
in rear since using helper bags he can lift it up but at the 6 inch level with 15 psi in the bags it wasnt that bad with the bracket cut off. His truck sat really nigh in rear im wondering now if gm changed the rear spring heights on the 2012s.
On his at the full 6 inch level I would notch it but it wasnt as bad as you think.
---------- Post added at 09:29 AM ---------- Previous post was at 09:26 AM ----------
id cut 2 coils out of your 5305 springs and honeslty I think you still will be ok with helper bags.
Right now how low is your front compared to rear?
275 50 20 you can go easy 4 inches because on a 305 35 24 a 3/5 drop is fine and your tires are over 1 inch shorter.
Hammered Avy
Do you have any pic's of a notch on nnbs and does it affect the towing capacity.
trevsyukon
