Custom buttons in empty dash spots
Matthew Jeschke
Sahuarita, Arizona
The factory seems to have provided some empty spots in the dash for buttons etc.
I was curious if any aftermarket companies came up with buttons for those spots?
I'd like to repurpose the onstar to control blutooth module...
Then a switch for lightbar,
and if possible a guage for transtemp, preferably expandable to other items. like the banks idash guages
Sent from my SM-A505U using Tapatalk
Nothing that I’ve seen that just snaps into those locations if that’s what you mean. There are OEM blanks for them, like the onstar one. Most people just add switches or whatever into the blanks. Kind of make your own.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Yeah I had figured that might be the case. Any idea of which switches look coolest? :)
Hoping to find inspiration for myproject. Tahoes esp 2nd gen ones seem to be the least modified for some reason. In my opinion they are best built of all.
wjburken
Eastern Iowa
What type of switch do you want?Rocker, Toggles, Push or Rotary?
There are a ton of options.
https://www.wiringdepot.com/store/c/18-Switches.aspx
ks03
Fool Excess Member
Stolen from
https://www.gmfullsize.com/threads/tech-every-possible-dash-switch-for-gmt800-trucks.176549/
Originally posted by
88GMCtruck
02GMCtruck
Joined Feb 9, 2009
Discussion Starter • #1 Dec 5, 2009
Got Bored.
With the help of a friend, we researched every possible dash mounted switch GM offered in the GMT800 series trucks/suvs. Note there is a break between 99-02 and 03-07c. The 99-02 switches are grey and typically have lettering assosicated with them, while 03-07c are black and use symbols instead of lettering. I have seen most of these switches in some form, and have pictures of most if anyone is interested.
99-02 Switches
Left IP Switches
- Traction Control - 15062589 - ACDelco #15062589
- Autotrac 4wd (NP8) - 15709327
- 4wd (NP1) – 19168767
- Power Fold Mirrors - 15062588
- Pocket - 15732033
Bottom
- Cargo Lamp - 15714159
- Fog Light - 15714113
- Cargo Lamp/Fog Light - 15752869 - ACDelco #D1552G
- Rear Wiper - 15714119
- Rear Wiper/Fog Light - 15735839 - ACDelco #D7062C
- Blank - 15735838
Right IP switches
Top* (housing is integrated with switch or plaque)
- Onstar - 12450568
- Rear Wheel Steering (quadrasteer) - 15177433
Bottom* (housing is integrated with switch)
- Onstar - 12450789
Left
- Aux Lamp / Emergency Vehicle Roof Lamp - 15722980
- Rear Object Alarm Disable - 15062424
- Electronic Suspension - 15052073
- PTO switch - 15040484
- Rear Fog (export) - 15715117 - ACDelco #D1570F
- Fog (export) - 15729517
Right
- Power Sliding Rear Window - 12463419
- Headlamp Leveling Activator (export) - 15036455
- Stabilitrack/Traction Control - 15062423
- Airbag Disable - 15036140
Other
- Blank Cover Single (pack of 5) – 15734687
- Blank Cover Double (covers both bottom openings) – 15075115
- 2 pod housing (blank top) – 15040483
- 3 pod housing (wide top pod) - 15074689
- 4 pod housing – 15207878
- Storage Compartment - 15756680
- Mat for Storage Compartment – 15024920
03-07c Switches
Left IP Switches
- Traction Control - 15764411
- Autotrac 4wd (NP8) - 15136039
- 4wd (NP1) - 15136040
- Pocket - 15732033
Bottom
- Cargo Lamp - 15143155
- Fog Light - 15143157
- Cargo Lamp/Fog Light - 15076588 - ACDelco #15076588
- Rear Wiper - 15143159 - ACDelco #D6316E
- Rear Wiper/Fog Light - 15143158 - ACDelco #D6378D
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- “SS” plaque - 15178169
- “Intimidator SS” Plaque - 15783816
- “Hybrid” plaque - 15803575
- Onstar - 12450789
Left
- Aux Lamp / Emergency Vehicle Roof Lamp - 15061687
- Rear Object Alarm Disable - 15763185
- Electronic Suspension - 10363575
- Accessory Power Receptacle On Off (Hybrid) - 15776718
- PTO switch - 12497678
- Rear Fog (export) - 15061688 - ACDelco #D1582G
- Fog (export) - 15061686 - ACDelco #D7095C
Right
- Headlamp Leveling Activator (export) - 15763184
- Stabilitrack/Traction Control - 15061684
- Airbag Disable - 15270598
Other
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Stolen from
88GMCtruck
02GMCtruck
Joined Feb 9, 2009
Got Bored.
99-02 Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
03-07c Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
dude super cool. very helpful :)
Mr. 960
It was from this post on GMFS that I found my fog light button with no wiper and no cargo light for my 06 Yukon after deleting my rear wiper.
Stolen from
88GMCtruck
02GMCtruck
Joined Feb 9, 2009
Got Bored.
99-02 Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
03-07c Switches
Left IP Switches
- Pocket - 15732033
Bottom
- Blank - 15735838
Right IP switches
- Onstar - 12450568
- Onstar - 12450789
Left
Right
Other
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
It's like a match made in heaven lol The cab over light switch is perfect! I just ordered one :) I think there's a back light on it. I'll have to figure out how to wire that into the dash illumination wires.
Then I'm curious, is there an aftermarket relay / fuse box? Something to add some expansion to the electrical system under the hood. I have plans to do overhead light bar, build in air compressor, and inverter.
HiHoeSilver
Away!
Chicago
Link to where you found that!?!?!?
SUBURBIAN
All Chevy
I cut out plastic from driver rear storage compartment (where 99-02 factory subwoofer was located) to allow entire area behind trim to be used as storage. This plastic became blank to replace small storage below HVAC vent on right side (same as pic above), where I mounted a dual input port from amazon which has a USB and aux input for aftermarket head unit.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
did you put a sub back in?
SUBURBIAN
All Chevy
No, in my 2003 Suburban, the sub is in the front center console, so the rear cargo area has a giant void of unused space where the subwoofer was located on the '99-'02 rigs. Instead of wasting this space and keeping a crate of junk in the back of my Suburban, I cut open this area (inside the small factory compartment) and use it to store a bottle jack, 4 way, raingear, jumper cables, etc.
jeffsyukon
I like this idea. Any photos?
Sent from my SM-G965U using Tapatalk
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
My switch came in. Look AWESOME, will look totally authentic. Here's where my questions get more in depth lol I have All Data DIY / factory service manual for my truck. I need to find wiring diagrams. I want to wire up as factory would have been for the cab over lights.
I cannot even figure out how to find wiring diagrams in All Data though? It's a bit of a PITA sometimes to search? Anybody know where I can find:
1. Factory wiring diagram for cab over lights?
2. Possibly know of anybody that's opened up the interior wiring harness / have any documents / videos etc about it?
I am assuming a wire comes out of the main bundle running length of dash behind pods. I need to hookup to dash illumination and then run the relay wires out. I see switch has 3 more wires? Not sure what extra / 5th wire is for on switch? Not really hooked up relays before lol Although I have a masters in computer engineering and designed such things for aircraft.
I think there's a connector bundle in driver side foot well. Is this where all the connectors link up to go through firewall? Otherwise I know I can push a wire through the boot on firewall but rather have it hookup in factory location.
Did the cab over lights use a relay? I'm assuming yes? However, I don't see any blanks to add more relays in my relay box, unless that's in the door box?
I have a few more modifications to make to the interior wiring harness for other projects (upgrade aux power for higher load capacity / add backup camera / exterior, install ALC wiring but have tire compressor in it's place / add ***** power to pumper etc). Any information diagrams etc on it is greatly appreciated :)
Thanks,
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Found a wiring diagram for the switch. It's the becon button. Came on some HD vehicles for a orange construction beacon. Trying to decipher rest of wiring and how to best make a system to hookup a light bar with it instead of a beacon. It seems it's been done, but on vehicles that were prewired with the switch from factory.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
SAVING MY NOTES HERE: Reverse engineering the beacon switch
Connector
PIN A: Blank
PIN B: BLACK: Ground?
PIN C: White - Power? ~ Fuse SEO 1 (15A?
PIN D: Purple - Dash illumination - indicates relay active
PIN E: Gray - Reference / Ground?
PIN F: Orange - BUTTON PRESS
Would be awesome if somebody had a electrical diagram for this back of this switch lol Probably I'm right but would take a lot of guessing out of things.
Durobans
