Justinj360
Senior Member
- Joined
- Jan 2, 2014
- Posts
- 476
- Reaction score
- 87
I'm trying to get to the bottom of my camber issue. I've had a 3" torsion key and 2" spacer kit installed on my 2004 Yukon AWD for a while and the tops of my front tires have always been visibly pointed out like this: \\--o--//
It's not drastic but my front tires wear noticeably on the outsides too. I have it aligned regularly and they must be using the stock specs for the alignment? It still has some room for camber adjustment if you look at the bolts and brackets. I'm not an alignment expert but can't they compensate for that some more?
I also talked to the shop that does my alignments and they said to find the lift kit's alignment specs. So I spoke with Rough Country and they said really nothing can be done further... That can't be right... Right?
