Coolant leak help. Common external points of failure?
ya I went back and looked I was way off it's around $100, I must have been thinking of something else
Yeah, the Gruven kits (Ts, hoses and clamps) are $95 each- $200ish total with shipping. The Stealth Ts are $30 each- $70ish total shipped. Hose and clamps are cheap, unless you want silicone.
Charlie207
Charlie207
LFOD, New Hampshire
After a couple days of checking levels and driving, and checking levels, it looks like there's still a slow leak somewhere on top of the old expansion tank leak. Not a great time of the year as I just down want to stand around the engine bay, or lay on the snow under the truck to hunt and peck.
89Suburban
Bull in the china shop
SE PA
ya set of oem T's and hoses will run about $100 or close to it, when I bought mine last time Amazon had the best price
I have had the t break off before luckily I was in town and not stuck on the side of the highway in no-where-ville
Mine broke off towing the boat home right after I picked up a pizza at 9 at night in a monsoon in the ghetto, freakin SUCKED. Thank god I had a spare jug of antifreeze in the back.
If this ever happens to anybody you can cut both heater hoses and dig the broken plastic nipple end out of the one heater hose and use it as a splice to bypass the heater core lines. You can use zip ties or tire wire for clamps.
When I replaced everything I put a brass splice into one of the heater hoses with spring clamps as an emergency bypass setup if it ever happens again
revrae
