Checked my engine hours today
HamPPV
Pennsylvania
Decided to check my engine hours today. When purchasing the PPV, I found out the unit was used in traffic control rather than regular patrol, so I figured the hours would reflect the hours of sitting and watching for traffic infractions, and it certainly does.
With only 77K miles on the clock, it would seem rather low for a 2013. However, the engine hours register at 16,325, so roughly 2 years of the 11 years it has been on the road, that engine has been running.
So I am guessing I am going to have to keep a close eye on oil use with this PPV.
Sparksalot
Bastrop County, Texas
Holy chit. Mine is over 9800 hours and now 211k miles.
woketradr
How's it doing for you. I bought a PPV with 100k miles, 2019 and has 14k hours.
daniellsonn
How do you check engine hours? Please
The push pin on dash doesn't provide info
Is there a sequence or?.. thanks in advance
Marky Dissod
Miles / Hours =MpH
77000 / 16325 = 4.72MpH
211/000/9800 =21.53MpH
195000/9800 =19.89MpH
190000/4100 =46.34MpH
100000/14000 =7.14MpH
mikez71
You need to push the DIC 4-button on the right side.
If you don't have one, you'll need to buy and install it.
2012 z71 223,886 / 6,342.3 = 35.3 mph
ppv cluster 106,442 / 11,934 = 8.9 mph
canada ppv 13,666 / 1,487.4 = 9.2 mph
Now I'm running the canada cluster, but I think I like my Z71 cluster more. Less cluttered looking.
I've noticed with the canadian cluster, once it is unplugged, it will default to metric next time it's plugged in.
PG01
Up here to the right
Shit.. not a tahoe but my work truck..4500 chevy van cab and chassis has 46 or 49k on it can’t remember right now.. that thing has ben running since i got it new in 2017 spring, summer, fall and winter..seriously tho starts at 645am when i get there and shuts off at 330pm when i leave.. 5 days a week…..ill check the dic tuesday because off Monday and now im curious as to engine hrs on it..
mikez71
With the engine off, push and hold the dash pin in and it will show you the engine hours.
I had no idea!
Works with my canadian PPV cluster.. so I guess it's programmed into PPV/SSV clusters.
SuperDave
Anioch/Chicago,IL
My 2010 PPV has around 150k on it, when I bought it the dash showed around 6k hrs on it. Recently had some work done to it that required a dealer visit unfortunately, after picking it up noticed the hours were reset and now shows around 16hrs when i actually seen it.
mikez71
I thought the hours wasn't reset-able? Was it some other work that involved a new cluster?
Or am I thinking about the gallons used? Makes more sense if hours isn't reset-able, but gallons might be..
Brace
